Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 11:42 AM
TC-Countryboy's Avatar
TC-Countryboy TC-Countryboy is offline
1995 Ford F-250
TC-Countryboy is starting off with a positive reputation.
Front Drive Shaft Clearance
Hello,
I am new to the site, and have a question for anyone with a lifted truck. I have had several Ford 4x4s, but I just acquired a 95 F250 with a 4" lift. This is my first lifted truck, and I was looking around under it, and noticed the front drive shaft was less than a 1/4" from the trans crossmember so it looks like it would hit if the front end was ever up in the air. Has anyone else had this problem, and what is the correct fix? I could cut and modify the crossmember, but if there is a easier fix, I would rather go that route.
Thank you,
TC
  #2 (permalink)
Old 07-01-2009, 11:59 AM
75F350's Avatar
75F350 75F350 is offline
1973 Ford F-100
My Garage
75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE.
Welcome to the site:
A modification to the x-member is common for these trucks. Some cut out a section, whle others re-locate the entire unit.
  #3 (permalink)
Old 07-02-2009, 09:11 PM
Lou Braun Lou Braun is offline
Lou Braun is gaining momentum as a positive member of FTE.
As 75F350 mentioned, it is relatively easy to do some surgery on the cross-member.
When I installed a lift on a '95 F250 I ended up installing an F-350 front driveshaft that had a double cardan joint at the transfer case. This allowed use of the standard cross-member and fixed that severe driveshaft angle at the transfer case.
If you do this modification you would also have to swap the yoke that comes out of the front of the transfer case with an F-350 yoke. This is not a very difficult job once you have all of the parts lined up.
Lou Braun
__________________
'06 F350XLT 4WD 6.0
'03 Cat MT295 4WD w/16 speed
  #4 (permalink)
Old 07-02-2009, 11:30 PM
1995 Ford F-250
Thanks for the replies, I believe for now, since I don't plan to do any severe 4 wheeling, I will do some modifications to the crossmember. It will give me a good excuse to get out the welder. I will wait on changing the shaft as eventually, I would like to get rid of the TTB 50 and replace it with a straight 60
Thanks,
TC
Tags
350 , angle , clearancing , drive , driveshaft , f250 , f350 , ford , front , lifted , sale , shaft , shafts , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
