Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 11:41 AM
387designs 387designs is offline
387designs is starting off with a positive reputation.
300 sound
One of my favorite things about driving an american vehicle is the sound, I have the exhaust note pretty dialed (third exhaust I've put on). It is dual 2" off the EFI manifolds y piped into a 40 series flowmaster with a y pipe out into dual 2 1/2 exit pipes. Ive found it sounds best with the smaller pipes building up the back pressure and then resonating out the larger pipes.
Leading to the real question, from tyhe research I've dont there isn't much of a gain with the chevy rockers, but will they give the truck a loopier idle sound?
Thanks,
Sean
  #2 (permalink)
Old 07-01-2009, 08:39 PM
flipklos flipklos is offline
flipklos is starting off with a positive reputation.
Try the 260 comp grind. The cam will give it a bit more lope. The 252 I got makes it sound like a diesel.
  #3 (permalink)
Old 07-01-2009, 09:25 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
owned by fords
1956 Ford F-100
My Garage
dustybumpers is gaining momentum as a positive member of FTE.
don't really make it lopy, but makes a big improvement in how it runs
__________________
Charlie
Join the Maryland Chapter click HERE
  #4 (permalink)
Old 07-01-2009, 09:35 PM
Dusty, Are you talking about the cam or the BB rockers?
  #5 (permalink)
Old 07-01-2009, 09:39 PM
owned by fords
1956 Ford F-100
My Garage
Quote:
talking about useing the 6cyl chevy rockers.
__________________
Charlie
  #6 (permalink)
Old 07-05-2009, 12:31 AM
optikal illushun's Avatar
optikal illushun optikal illushun is offline
optikal illushun is starting off with a positive reputation.
unless its a pre-85? engine that wont work.
__________________
93 F150 XLT 4x4 Modded 300/Built E4OD/SAS-79 Dana 44-5" lift/33" ProComp MTs/15x8 AR 147's/Crane 503905 cam/Ported intakes/V8 throttle body/Hedmen headers/some kinda exhaust/Crane coil-Taylor wires/Cervini's RamAir hood/Diamond lights/Infinity-stereo
1988 F350 Custom 4x4 7.3IDI/ZF/RayWel lid w/ Opti'ized ram air/"G" codes/True 2.25" duals/315-75-16 ProComp Xtreme ATs/16x8 White waggies/Alpine-Infinity stereo
  #7 (permalink)
Old 07-05-2009, 10:21 AM
owned by fords
1956 Ford F-100
My Garage
Quote:
don't know where it changed, but you can put in screw in studs, and convert to adjustable rockers on the ones that didd'nt come that way
__________________
Charlie
  #8 (permalink)
Old 07-05-2009, 02:19 PM
Harte3 Harte3 is offline
Harte3 is starting off with a positive reputation.
If you are building back pressure you are going backwards. The desired dynamic is velocity, not back pressure.
The Chebby rocker swap is usually used with a stock cam to get a little more lift and replicates a mild RV type grind but at about $50 mol for the Chebby rockers, the ROI is not bad vs the cost of a cam.
A mild port/polish and port match on the head and manifolds even on a stock unit produces fairly decent results and is necessary to get optimum results from other modifications like cams, 2v or 4v carbs, EFI manifolds or headers, etc.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
