Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 11:35 AM
WATTSUP!'s Avatar
WATTSUP! WATTSUP! is offline
WATTSUP! is starting off with a positive reputation.
2009 F-150 rims?
What are the width of the 18" rims on the 2009 f150 4x4 XLT? I'm thinking about putting a leveling kit on and want to run 33x12.50"s but like the rims that are stock and don't want to change them. Will 12.50's work and be safe on stock wheels?
__________________
2009 F-150 4x4
1989 F-150 (Lil Red) 4x4 9in. lift, 4.88 gears, 36in. IROKS
1979 Bronco (Big Red) 434 stroker, 9in. lift, 44 in. Ground Hawgs, 5.13 gears, detriot locker in the rear, Auburn pro series in the front.
If it blows up, build it BIGGER!
  #2 (permalink)
Old 07-01-2009, 01:59 PM
tylus's Avatar
tylus tylus is offline
Navy Nuclear Mach. Mate
2008 Ford Expedition
tylus has a good reputation on FTE. tylus has a good reputation on FTE.
7.5" wide
20" are 8.5" wide
guys do run that size, and have zero issues. But the 7.5" rim is narrower than the minimum recommended from all the tire manufacturers.
I suggest you look into a 305 width tire. It will be alot safer on the 7.5" rim...and you won't have clearance issues. 12.5" wide is very very close to rubbing the upper control arm
__________________
2008 Expedition EL - Hers....Bone Stock
2009 Mustang Bullitt - Mine..Not Quite Stock
Currently deployed. See y'all on the flip-side.
Tags
09 , 125 , 2009 , 33x1250 , 4x4 , f150 , rim , rims , selling , size , stock , tire , top , wheels , width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
