Hi Unregistered, it appears you have less than 25 posts. If you wish to sell something through our marketplace you will need 25posts to start a thread, you may respond to existing threads however.
Vendor Specials, Discounts, Product Announcements and Group BuysThis is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Then chances are that your clock spring may be worn.
This part is designed to replace the factory clock spring with no modification. We have the part at a fraction of the cost from a mechanic or the dealer.
The clock spring in your car is a very important part of your vehicle's airbag system. It sits behind the air bag and allows the mounting of steering wheel mounted accessories such as cruise control and audio controls.
It also provides power to the airbag so it can deploy during a crash. The electrical connections to the steering wheel and the airbag have to be in the form of a spring because the steering wheel turns and the electrical connection must be maintained no matter the angle of the steering wheel.
Over time and many turns the clock spring wears out and may cause failure of electrical components on the steering wheel or worse, failure of the airbag to deploy.
If your airbag light is on or your steering wheel mounted controls aren't working anymore, replace your clock spring with the right part the first time. You will save money in the long run
Click on the link below to purchase through our secure website.
