Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 10:10 AM
mitch_c mitch_c is offline
mitch_c is starting off with a positive reputation.
Question 03 Ranger w/No Turn Sigs or Emerg Flashers
'03 Ranger has no Turn Signals or Emergency Flashers. Fuse is OK.. Switch OK... ??
  #2 (permalink)
Old 07-02-2009, 11:48 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
There are two fuses to check (#10 and #21) in the cab fuse box, both 7.5A.
If it's not a fuse, then it could be that the flasher relay (located in a multi-relay box under the steering column) is bad, or there is a problem with the multifunction switch.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #3 (permalink)
Old 07-02-2009, 05:57 PM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is starting off with a positive reputation.
I had same issue with my 03. I removed flasher relay, cleaned contacts and reinserted. That solved it and it hasn't happened again since.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
