Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 09:17 AM
kaduh kaduh is offline
1996 Ford F-150
kaduh is starting off with a positive reputation.
Engine barely turns over
I have a 96 F-150 that I have not started in three years. I put a new battery, terminal connections and had the starter checked out. It just barely turns over when I try to start it. I did notice that the negative lead gets pretty hot after a few turns of the key. I checked and cleaned both positive and negative connections to the starter and block/chassis. Any help or suggestions will be greatly appreciated.
  #2 (permalink)
Old 07-01-2009, 09:52 AM
dneinstadt dneinstadt is offline
dneinstadt is starting off with a positive reputation.
Why in the 2009 section??
To help, I would check connections at the solonoid to make sure you have a good contact there. Has the wiring been changed since stock? You may want to consider a larger wire to reduce resistance..
Dan
  #3 (permalink)
Old 07-01-2009, 04:01 PM
ottawaguy's Avatar
ottawaguy ottawaguy is offline
ottawaguy is starting off with a positive reputation.
A lot can happen to a vehicle when it sits for 3 years....from rodents to rust.
Hard to say what the problem is...without more info.
Always post as much info when you want help to diagnose a problem.
It will go a long way in helping you to get good responses from the other members here.
__________________
Dave
1994 F-150 XL Supercab 4x2 300CID-I6
1994 Bronco XLT 4X4 302CID-V8
  #4 (permalink)
Old 07-01-2009, 04:34 PM
quicklook2's Avatar
quicklook2 quicklook2 is online now
quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE.
having 2 threads at the same time on the same subject wastes everyones time.
__________________
"To believe is to know you believe, and to know you believe is not to believe." ~ Jean-Paul Sartre
  #5 (permalink)
Old 07-01-2009, 04:56 PM
ottawaguy's Avatar
In the same forum to boot...
I agree...
That will not help you get a faster answer.
I can see bumping your thread if it went unanswered, but to start a new thread?????
__________________
Dave
  #6 (permalink)
ottawaguy's Avatar
I agree...
In fact I think it will impede your search for answers....and some may not respond at all.
__________________
Dave
  #7 (permalink)
Old 07-03-2009, 12:29 AM
dyoungen dyoungen is offline
dyoungen is starting off with a positive reputation.
The first thing I would suggest is to remove the battery connections and clean them with a good battery brush. When the cables are getting that hot they seem to be telling you where the problem is. I"ve had connections get corroded and when I tried to start the truck, the connectors get super hot. Cleaned the connectors and problem solved.
  #8 (permalink)
Old 07-03-2009, 05:28 AM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE.
I think the first thing I would do is pull the plugs and put a wrench on the crank pulley and see how easily the engine turns over.
  #9 (permalink)
Old 07-03-2009, 12:03 PM
berriault berriault is offline
berriault is starting off with a positive reputation.
put a new ground wire on it
  #10 (permalink)
Old 07-03-2009, 12:41 PM
White 97 xlt White 97 xlt is online now
White 97 xlt is starting off with a positive reputation.
Quote:
That and if it turns fairly easy (no ten foot pipe on the wrench), leave the plugs out and squirt a little oil in the cylinders and see if it frees it up any, if so squirt some more oil in there and hit the starter, turn it over for a few seconds for a total time of a minute or so, that should scrape most of the rust off the cylinder walls....
At least this will rule out rusted cylinder walls.... and if it has sat for three years and a valve was open I would bet on rust!!!!!
  #11 (permalink)
Old 07-04-2009, 11:53 AM
timbersteel timbersteel is offline
timbersteel is starting off with a positive reputation.
3 things I was curious about...
1. If this engine sat for 3 years, has the oil been changed, prior to cranking it over for the 1st time?
2. If the oil wasn't changed, what weight oil was in it before? Hopefully nothing more than 10w-30, over 3 years, that has absorbed moisture, oxidized from prior combustion 3 years ago. Even the lightest oil can impede lubrication, when it's contiminated.
3. Not sure, but when my alternator had bad diodes, it would get the batt. connections very hot...May not apply to the neg. batt. cable or terminal post..
Do what White 97 xlt and Lazy K have advised. Have also heard using Marvel Mystery oil or PB blaster squirted into the plugs holes, and then letting them sit. If the Piston walls have rusted, then you will have luck letting the oil sit and seep in the head to free them, and lubricate the wall since it hasn't seen oil pumped in 3 years.
If you can find a hex tool, then you can get a electric drill and fabricate an extenstion to connect to the oil pump shaft and prime the oil pump, I wouldn't skimp on oil either. If you are trying to crank this engine with the oil that was in it 3 years ago, it prolly had moisture and other contiminates in it.
Priming the oil pump also helped to push oil up thru the head and into the galleries, where there is likely more contiminates, and no oily film after 3 years of no lubrication.
and the 300's also have larger oil passages I believe from what I have read on this site, so being meticulos is key here. Don't wanna damage the engine after such a long sitting.
Best of luck, and Hope it gets running for you!
__________________
1992 F-150 I6 4.9L 300 110K 4x4
2004 Dodge Hemi, 4x4, 1500, 20K
"He's one brick shy of a load..."
  #12 (permalink)
Old 07-07-2009, 12:04 PM
1996 Ford F-150
Thanks for all the help. Sorry about the double post as I am new and I didn't realize that I had originally posted this in the 2009 section. I asked the admins to remove it as I was going to post it in the 1996 section and maybe they just moved it, hence the double post.
  #13 (permalink)
Old 07-07-2009, 12:13 PM
ottawaguy's Avatar
After noticing the comment about the 2009 section, I figured that was the case but the edit button disappears rather quickly...and somehow, I ended up double posting,...sooooo
Have you had any luck with the truck?
__________________
Dave
  #14 (permalink)
Old 07-07-2009, 12:30 PM
1996 Ford F-150
I got new plugs and some Marvel Mystery Oil last week before the long weekend and hope to get to it today. Rained here in Houston this morning for the first time in a couple of months, so it will probably be this afternoon when it dries up a little. I'll let it sit a couple more days to loosen any sludge in the cylanders before I try to crank it again. I'll keep everyone posted with the trial and errors.
  #15 (permalink)
Old 07-07-2009, 12:36 PM
ottawaguy's Avatar
I hope things work out for you...
__________________
Dave
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
