Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-03-2009, 04:18 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
Quote:
Originally Posted by XzXPatrickXzX View Post
Oh, I'm sorry I did not realize this was Ford Grammar Enthusiasts. Please accept my apology with my deepest regards to the trauma bestowed on you while reading my post. Or you can kiss my ass either way is fine with me.
And look. You can spell and punctuate. Was it really that hard?
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #17 (permalink)
Old 07-03-2009, 04:25 PM
uncle.stosh uncle.stosh is offline
uncle.stosh has a good reputation on FTE. uncle.stosh has a good reputation on FTE.
prolly wuz ez r 2 axe it the way it wuz b4.
omg lol
God I HATE that..........
  #18 (permalink)
Old 07-03-2009, 09:21 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
owned by fords
dustybumpers is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by uncle.stosh View Post
I was on my 4th cup when I posted and fully awake.
Festus put it best. You aren't going to gain any respect around here with such poor grammar. Not from me any way.
Plus the fact that what you posted had nothing to add to the topic. Nobody here needs to hear that you have issues either. We all do and this forum is not the place for you convey them.
Normally when I see such jibberish, I just skip over the post and don't even waste my time.
If you need help with something, then I'd be glad to help if you ask properly and sensibly.
you go stosh, glad to see someone speak up. if I want to hear talk like that I can go see my 3 year old grand son. back to the thread. yes the bronco seats fit, I have them in 2 of my trucks. the outside holes line up, drill new holes for the inside brackets. as stated before, make sure to use large fender washers under the bolts from the bottom, to strengthen the floor.try to get the seat belt clip ends from the donor bronco. the ones from a bench seat are shaped a little different, will work, but it is easier to hook/unhook the ones from the bronco.
__________________
Charlie
Join the Maryland Chapter click HERE
  #19 (permalink)
Old 07-04-2009, 09:45 AM
Good point about the seat belts. I got lucky and was able to find a good set from another Super Cab truck.
When I first grabbed those seats, I did not even think about grabbing the seat belts too and when I went back the Bronco was already crushed.
I got lucky and found those nice seats in one of the yards that I frequent for $17 each. They are Saddle Tan, but match the Fawn interior I have close enough.
  #20 (permalink)
Old 07-04-2009, 12:14 PM
owned by fords
your bad stosh. the last set of bronco seats and consol cost me $100, and the driver's seat had a cigarette burn in it
__________________
Charlie
  #21 (permalink)
Old 07-04-2009, 02:35 PM
Quote:
Nope, not bad but GOOD. I have a system worked out for finding stuff like this.
I have several good sources for these parts and it's taken me quite a while to find that pair. Out of a hundred trucks that I look through, I may find one good part if I'm lucky.
I travel daily to several places within a hundred mile radius and you have to be quick to find stuff like that. If the truck or Bronco is in the yard for more than a day or two I am already too late. It's already been picked through.
The key is to get there the day it hits the yard. Sometimes I get there early and wait for them to bring the fresh vehicles out.
  #22 (permalink)
Old 07-04-2009, 02:36 PM
1980 Ford F-350
My Garage
Stosh. Do you have any pics of the outside of the truck those buckets are in? If it half as clean as the inside that is a nice truck.
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #23 (permalink)
Old 07-04-2009, 02:52 PM
None of the exterior other than what's in my gallery.
I did break down the other day though and got wood!
I ditched the black and gray waffle weave bezels, black door handles, window cranks and knobs in exchange for chrome. I wasn't sure if I was going to like the Rosewood, but it's growing on me. It makes the truck look more vintage IMO.
I also repainted my needles back to the stock orange instead of red. While I had the cluster out, I also installed new 194 bulbs and I finally got around to re-installing my transfer case shifter boot. Now that I have the correct radio bezel for the clock, one of those went in too.
All I need to do is find a good working shaft style radio. I did find a couple in the yard, but the preset buttons didn't work.
Here is a shot though the rear slider and from the driver's side door:
  #24 (permalink)
Old 07-04-2009, 03:17 PM
owned by fords
that's really nice. I'd be proud to park my rear in there!
__________________
Charlie
  #25 (permalink)
Old 07-04-2009, 03:52 PM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE.
Those are easily fixed.
Take the top off the radio, being careful not to damage the noise supressor attached to the top.
At the right side of the radio, where the tuning dial shaft comes in and connects to the tuner, you will find a round circular part with a rubber "Washer" sandwitched between the two metal sections and a white plastic gear.
This rubber washer is supposed to slip, because one side is hooked to the dial, and one is hooked to the preset buttons on the tuner. More than likely with the radios that the preset buttons are stuck, this rubber washer is "stuck" to the two metal components it's sandwitched between.
You basiclly "unstick" the rubber washer, from both sides of the round metal component, and use some sand paper and some dielectric grease to keep the component and rubber washer from "sticking together". Use the grease sparingly or your tuning dial will slip too much, and you can't tune the radio.
Hopefully this makes sence. Do not know the right terminology for what the internal part is called. Once you have the top off the radio, it should be obvious.
  #26 (permalink)
Old 07-04-2009, 03:55 PM
1980 Ford F-350
My Garage
At the right side of the radio, where the tuning dial shaft comes in and connects to the tuner, you will find a round circular part with a rubber "Washer" sandwitched between the two sections.
Im gonna have to try that on my 86!
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #27 (permalink)
Old 07-07-2009, 11:34 AM
bfbiker's Avatar
bfbiker bfbiker is offline
bfbiker is starting off with a positive reputation.
Talking seats
My 85 f 150 S.C.has the flip up pass seat and center con in it.I' thinking it was stock
The 92 has a bench that I need to swap out for bucketts cause of my leg when I'm not driving it
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
