Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 02:45 AM
dragonmaster093's Avatar
dragonmaster093 dragonmaster093 is offline
dragonmaster093 is starting off with a positive reputation.
need help
hey guys just traded my dentside for an 86 xlt lariet super cab 4x2 got one issue going down the road it acts like youre turning off fuel pump it cuts out for split second and does this off and on from starting stops when idling it seems to surge a little its fuel injected 5.0 it also has dual tanks po said sometimes on front tank it tries to switch tanks but idk does this on either tank but more pronounced to me on front friend said map sensor but i dont wann replace it if not bad
__________________
new to me 1986 f150 4x2
'76 high boy now gone
'94 skylark
'77 monte carlo
sam
  #2 (permalink)
Old 07-01-2009, 07:56 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Have you asked the computer what it thinks might be wrong?
  #3 (permalink)
Old 07-01-2009, 10:39 AM
no havent seen a check engine or other such light
__________________
'94 skylark
'77 monte carlo
sam
  #4 (permalink)
Old 07-01-2009, 10:59 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
i would check you fuel presssure and you spark
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #5 (permalink)
Old 07-02-2009, 06:31 PM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE.
Quote:
That's because it doesn't have one.
You have to physically ask the computer through a diagnostic, if it's got any codes.
First year of a proper check Engine light was 1988 F-series.
Some mid-80's between 1984-1987 have an Emission light, but this doesn't do anything but to remind you to check the computer for service codes. It comes on every 60,000 miles or so, if you have a problem or not, and needs to be reset. The Emission light is really worthless and useless.
  #6 (permalink)
Old 07-02-2009, 07:27 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all
Yes, it might throw a ignition error code, so that would tell you the problem is there. If the computer doesn't have any codes, then you can concentrate on the fuel system. Here's a site that tells you how to pull the codes using a testlight or voltmeter.
www.fordfuelinjection.com
__________________
Dave F
1989 F250 XLT Diesel
  #7 (permalink)
Old 07-04-2009, 03:41 AM
was under hood and noticed that off map sensor is a vacuum multi port but nothing else pluged in and that up on top of plenum by thottle linkage there looks to be a vacuum port but no line could this be part of my problem
__________________
'94 skylark
'77 monte carlo
sam
  #8 (permalink)
Old 07-04-2009, 04:53 AM
1981 Ford F-150
You would have to check the Emissions lable and vacuum diagram on the radiator support.
Sometimes it is normal to have a open vacuum port like that, with a filter on it. Usually on Ported vacuum switches, or solenoids. It bleeds off vacuum depending on how it's switched.
The only way to really tell if it's supposed to be that way is the vacuum diagram on the Emission lable.
A picture of the effected component may also shed light on it.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
