Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 01:05 AM
justboughta77 justboughta77 is offline
justboughta77 is starting off with a positive reputation.
Talking 302 build
Hello all, Been a long time since I've posted. I have a 1977 f100 short box, 2 wheel drive with a 302. I'm getting ready to build another 302 to replace the original, but I need help and ideas.
Here's what I have so far:
  • Headman long tube headers
  • RPM dual plane intake
  • Holley 650 DP HP
  • MSD 6AL ignition box
  • MSD Blaster III coil
  • 8mm plug wires
  • 14" open air element
  • All Felpro gaskets
  • polished aluminum valve covers
I am about to pull a 302 from a mid 90's Explorer with GT40 heads. My questions are as follows:
What distibutor should I use?
What size cam?
Roller rockers?
Etc......
Any help would be greatly appreciated. Thanks in advance.
  #2 (permalink)
Old 07-01-2009, 07:22 AM
guitarnik's Avatar
guitarnik guitarnik is offline
1990 Ford F-250
guitarnik is starting off with a positive reputation.
1.get an accel dist. 2.cam depends on what you wan to end up with power wise. 3.yes.
4.????
__________________
90 f250 4x4 5-speed 351w headman LT's 33x12.5 coopers CHEVROLET-Cheap Hardly Efficient Virually Runs On Luck Every Time
  #3 (permalink)
Old 07-01-2009, 07:43 AM
79 f-150 guy's Avatar
79 f-150 guy 79 f-150 guy is offline
79 f-150 guy is starting off with a positive reputation.
you could also go with a hei distributer, i used one on my 302 to simplifie everything.. worked great, and the best part was the whole ignition system was 2 wires.. but with that your msd stuff is unusable. also i woud go with a good crane cam and crane roller rockers.
i did the same swap, pulled a running explorer gt40p engine from my local junk yard.. but i ran into a snaffu, you cant just use any headers on gt40p heads. you need the specail ones they sell just for them, becouse of the spark plug angle. if you are lucky it is a pre 95 engine, then your headers will work. but 96 up like i have you need the specail headers.. you can tell by looking at the head under the valve cover, if it says gt40p then you need those headers.. thanks
  #4 (permalink)
Old 07-01-2009, 05:16 PM
gearhed1971's Avatar
gearhed1971 gearhed1971 is offline
1973 Ford F-100
gearhed1971 is starting off with a positive reputation.
Good luck getting Crane equipment.They went out of business 3 months ago.
__________________
gearhed1971
1973 f100-390 4wd
1963 falcon-under construction
1951chebby special deluxe(for sale)-SOLD!!!
daily beater poontang sunfire
  #5 (permalink)
Old 07-04-2009, 04:39 AM
I obviously am looking for as much power gain as possible, any other ideas that might be helpfull.
Im also getting ready to buy a set of DJM dream beams, Pete and Jake 4 link and coilovers. Anyone had luck with these things or seen them on anything.
  #6 (permalink)
Old 07-04-2009, 11:08 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Consider a cam such as the Comp 35-430-8 or Ford E303 for about 330 crank HP at 5500rpm, This will put TQ peak at about 4500rpm so 4.10 gears are a minimum with very little grunt below 2500rpm.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #7 (permalink)
Old 07-06-2009, 05:01 PM
clgreer clgreer is offline
1974 Ford F-100
clgreer is starting off with a positive reputation.
I just put a 5.0 roller motor in my 74 f100. i used gt-40p heads with flowtech longtube headers. the only plugwire that i have an issue with is #5. I just wrapped the postion near the wire in some exhast wrap. seems to be doing its job pretty well. i plan to put a 90' boot on there soon and see how it works. but all other wires are more then out of the way of the tubes. but you will have an issue getting the plugs in and out. make sure they are in before you bolt the headers up or youll be sorry...... cant get the socket in there with them on.
Tags
100 , 1973 , 302 , 73 , build , cam , crane , f100 , ford , ideas , ranger , rockers , roller , suggestions , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
