Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 07-01-2009, 12:08 AM
madrockwyo's Avatar
madrockwyo madrockwyo is offline
madrockwyo is starting off with a positive reputation.
c6 stuck in first gear?
I am posting this for a friend who just had a used c6 installed in his 80's bronco by a retired master mechanic, but now the trans is stuck in first and the mechanic has not seen this before. what could cause a c6 to not shigt out of 1st?
__________________
Scott
1979, F250 4x4 400/C6 reg cab XLT Ranger Chrome Yellow/ White
2000 Extended cab Ranger 4x4 V8/auto
1979 F150 4x4 351m/manual parts truck; 1963 Ranchero rolling chassis
1967 Bronco wagon 4x4 289/3 on tree
1961 and 1963 Ford Falcon Rancheros 170/3 on tree
  #2 (permalink)
Old 07-01-2009, 08:13 AM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE.
I`m not an expert but my guesses would be kickdown rod not fitted right or no vacuum to the modulator or bad modulator.
  #3 (permalink)
Old 07-09-2009, 12:04 AM
jimmyjoejr jimmyjoejr is offline
1979 Ford F-150
jimmyjoejr is starting off with a positive reputation.
My C4 had same problem after a friend took the pan and valve body off for inspection, turns out he didn't line up the gear selector linkage correctly when installing the valve body causing it to not shift out of first gear. It was a simple fix, just remove the pan and valve body and make sure the linkage is lined up. Hope that helps!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
