First time posting on the forum. Thanks for any help you can provide.
Got in my truck to leave work tonight, turned the steering wheel a small amount, heard a "pop" from under the hood, and then lost all power steering and 90% of brakes.
Truck is an '09 250 6.4 Lariat with under 2k miles. I looked in the owner's manual, couldn't find a fuse or relay which would control both the steering and brakes and then i searched this forum and found the exact same thing happened to another unlucky guy. Looks like it needs to be towed to the dealer. Good thing I wasn't on the highway or going down a hill.
Any of you all know if this is a fix I can do easily or is a pump issue as another thread from '08 indicated?
Sounds like a Hydroboost problem or failure. It's brand new and under warranty so I wouldn't touch it...let the dealer fix it. Moreover, with Ford cracking down on warranty claims, if you do work on it and something else fails, they may try to deny a warranty claim for it.
__________________ John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
