Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 10:49 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32 weekendwarriorfsw32 is offline
2004 Ford Excursion
My Garage
weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE. weekendwarriorfsw32 has a great reputation on FTE.
Question about Regen?
Well hello every one,
I am the proud new owner of a 2008 F 450 King Ranch with 80,000 Miles on it. On the way from Houston to San Antonio which is about 200 miles It went into regen mode 2 times for about 5-7 min. Is this normal? It seems like it does it a lot,
Thanks
Nick
__________________
Nick PAA#9
08 F-450 K R 6.4 SPARTINIZED, DPF/CAT GONE
04 X 6.0, 08 towing mirrors, 15k hitch, Firestone air bags
01 X 7.3, TN BB turbo, Dp tuner, ITP RR, RR up pipes, 4 Dipricol gauges,MBRP 4inch, 6637,650 dash with 2 auto meeter gauges, RR boots,
95 F-250 7.3, 6637
  #2 (permalink)
Old 07-01-2009, 12:43 AM
pilotshot pilotshot is offline
pilotshot is starting off with a positive reputation.
Nick:
Regen applications and duration vary with a lot of things. For example, if you are towing you will Regen more often due to soot from heavy hauling,. Regen will increase if you use LSD , not ULSD fuel, or if you use CJ-I oil instead of CJ-4 oil. Bio fuel will increase the amount of regenerations. I have also noticed that if I shut down near the end of Regen it will not return to Regen on start up but since the Regen had a bit to go it will Regen sooner the next time .
The most important Regen message to pay attention to is the 'Drive to Clean Exhaust Filter'. Do as the message says: drive until the Regen cycle is over.
If the truck is Regenerating too often the P2459 code will show up in your PCM.
Therefore enjoy your truck , letting it Regen when it wants to. The sensors will determine when you need to burn out the soot accumulation. Lastly your tail pipe must be clean with no soot in it or the DPF is faulty.
__________________
2008 6.4L F-350 Lariat SD 4x4 3.73 auto. Oxford White with Pueblo Gold. Pulling 2005 26/31 foot Titanium 5th Wheel.
1995 Explorer 4.0L auto
  #3 (permalink)
Old 07-01-2009, 12:57 AM
2004 Ford Excursion
My Garage
Thanks dude!
__________________
Nick PAA#9
95 F-250 7.3, 6637
  #4 (permalink)
Old 07-01-2009, 06:15 AM
ctownson ctownson is offline
ctownson is starting off with a positive reputation.
Never use LSD; you MUST use ULSD!!
  #5 (permalink)
Old 07-01-2009, 07:45 AM
waverunner800 waverunner800 is offline
waverunner800 is starting off with a positive reputation.
Nick,
I regen about every 200-250 miles, unless, as pilotshot notes, it trys to regen when I'm almost at my destination (as it did earlier this week). The mileage between varies alot....so, just enjoy the truck and don't worry too much about it!!
  #6 (permalink)
Old 07-05-2009, 05:00 PM
whporwil whporwil is offline
whporwil is starting off with a positive reputation.
Hi Nick This is funny, I live in Minnesota and buy a 450 from Califorina and you live in Califorina and buy a truck in Texas. We have to much free time, dam the internet. As you know on my return trip my truck went into regen twice in 650 miles and once on the way down with the 350. Both regens in the 450 were short compaired to the 350 which has always lasted about 20 minutes it seems. I was thinking because the truck was running at a higher rpm and also hotter not only would that cause it to regen more often but also quicker, I am by no means an expert but this could be a reason. I do have a slight dis coloring in my tail pipes as I did with the 350 but it seems if you take it in and it's is not throwing a code the dealer will tell you that's normal. I have another 08 F250 in camp right now and his tail pipes look like the day it came from the factory. However he has a check engine light on now and is waiting to take it to a dealer tomarrow before heading home. By the way my truck was a victim of Califorina law. The check engine light came on three times so Ford had to buy it back and I got it from a dealer in Missouri. It seems none of the dealers could figure out the truck had a bad sensor. Again if it doesn't throw code they don't know what to do.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
