Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 10:44 PM
jesuscowboy jesuscowboy is offline
jesuscowboy is starting off with a positive reputation.
Stock 351W Camshaft Specs
Does anyone know the duration and lift for a stock 92 camshaft. Also what brand or type of lube/oil do you guys recomend for a rebuild. Had guy tell me to use ATF on cylinder walls?
  #2 (permalink)
Old 07-01-2009, 10:03 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
The cam produces about 0.416" lift and 260 duration at the valve... pretty restrictive on this motor. Regular 10w30 is what you want to use on a rebuild for the initial breakin period along with some breakin lube.. usually supplied with the cam.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #3 (permalink)
Old 07-01-2009, 12:16 PM
is that SAE duration of .050 duration
  #4 (permalink)
Old 07-01-2009, 01:20 PM
Conanski's Avatar
1990 Ford F-150
That's the seat to seat or advertised duration, at 0.050" it's down around 200-210 deg.
__________________
Paul O
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
