Clunking Noise when turning - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-30-2009, 10:31 PM
jdevarie jdevarie is offline
jdevarie is starting off with a positive reputation.
Unhappy Clunking Noise when turning
Hello all and thanks for keeping up this great site. I have a 2000 F250 SD with the V10 engine. The problem that I am having with it as of late is that whenever I perform a full turn I hear some clunking coming from the front end. The clunking is similar to that heard from cars that use CV joints FWD but of course it sound more "manly"
Anyways, my truck has the full axle on front so I suppose it could be either the u-joint at the hub or the hub itself. I would like some pointers so I can acquire the required parts.
thanks in advance.
Jim
Old 06-30-2009, 10:45 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Mine did it too until I serviced the hubs. You should do that before you do anything else unless it's been done. It's probably the joints making the noise. There are posts in here on cleaning/greasing inner hub and locking hub. I made a post on the inner.
Old 06-30-2009, 10:51 PM
Thank you very much. That is nice to hear. I will research that. Hopefully it will stop raining up here (boston) so I can get it done :-)
regards,
jim
Old 07-01-2009, 12:12 AM
Robs06SuperDuty's Avatar
Robs06SuperDuty Robs06SuperDuty is offline
Robs06SuperDuty is gaining momentum as a positive member of FTE.Robs06SuperDuty is gaining momentum as a positive member of FTE.
my truck was doing it a few months ago, I had just assumed that I had the hubs engaged but I didnt, they might not have disengaged. it doesnt do it now.
Old 07-01-2009, 12:24 AM
If you get too much friction in the hubs they can spin the joints even though they are unlocked. After I did a greasing of the wheel and locking hubs it went away on mine.
Old 07-01-2009, 01:27 AM
Doubleubar Doubleubar is offline
Doubleubar is starting off with a positive reputation.
Another Source of a Clunk
While the hubs can provide the clunking noises, it is also possible for worn stabilizer bushings can also provide some lound clunking noises.
I have a 2000 F350 and had a clunking noise in the front end when I was making a left turn. I initially thought it could be one of the hubs but new bushings for the stabilizer bar eliminated the noise.
If you service the hubs and still have a clunk I would check the bushings on the drop links and those connecting the bar to the front axle.
Glenn
Old 07-01-2009, 12:51 PM
Powerstrokin_350's Avatar
Powerstrokin_350 Powerstrokin_350 is offline
Powerstrokin_350 is starting off with a positive reputation.
I have the same problem as well. New ball joints, new wheel bearing and hub assemblies on both sides, new warn non auto hubs, and my noise is more of a growl, not a clunk. only does it turning left and can feel it in the steering wheel. still maybe the stabilizer bar?
Old 07-01-2009, 01:04 PM
Oh, and its lifted if that changes anything
Old 07-01-2009, 01:25 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Sounds like the axles are turning. Either the hubs are locked, stuck, or the needle bearings (inner spindle bearing) is dry and rotating the axle even when the hubs are unlocked.
Old 07-01-2009, 01:27 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
If you find you need to do some maintance here is a great website to help:
http://www.guzzle7pt3.com/index.php
Old 08-18-2009, 09:27 PM
thank you
Thank you all for the help. Will get this done shortly!!!!
Old 08-22-2009, 12:16 PM
maverick5.0 maverick5.0 is offline
maverick5.0 is starting off with a positive reputation.
there is also a service bulletin on the drive-shaft clunk noise and to use teflon grease on the transmision output shaft so the drive-shaft can slide fore and aft... good PM since you will be wrenching away...good luck...-mel-
Old 01-09-2014, 02:14 PM
EricPero's Avatar
EricPero EricPero is offline
EricPero is starting off with a positive reputation.
Do you have the service bulletin #? I am experiencing bad clunking when turning the wheel in 4x4 at slow speeds - new ball joints, new u-joints in axle shafts and new wheel hubs.
Quote:
Old 01-11-2014, 11:46 AM
galaxie460 galaxie460 is offline
galaxie460 is starting off with a positive reputation.
My clunk was the sway bar bushings and links, it sounded like it was right under my left foot, did it when I turned into a driveway then everytime you hit a bump.
Old 01-11-2014, 04:51 PM
Krewat's Avatar
Very old thread - 5 years
Quote:
That is somewhat normal. These trucks do not use "CV" joints in the front axles, so when in 4x4, you WILL hear some slap back and forth with the wheels turned.
axle noise and clunking stanimals2 1997 - 2003 F150 5 01-05-2014 07:54 AM
Full-lock clunking with hubs locked in? troverman 1999 to 2016 Super Duty 5 06-05-2013 09:28 PM
Front End "Clunk Clunk Clunk......" MDSuperDuty 1999 to 2016 Super Duty 9 12-05-2011 08:37 AM
Front end clunk davidjurss 1999 to 2016 Super Duty 11 07-18-2011 10:02 PM
Where's my Clunk comming from? Already did ball joints strokerspeed 1997 - 2003 F150 5 12-01-2010 02:36 PM
Tags
clunk, clunks, drive, end, f150, f250, f350, ford, front, makes, noise, rear, shaft, steering, truck, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
