Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 10:14 PM
Buckboard6-300's Avatar
Buckboard6-300 Buckboard6-300 is offline
2003 Ford F-250
My Garage
Buckboard6-300 is starting off with a positive reputation.
what should be done for a good tune up for the 300 6 ?
im getting my truck: the Buckboard ready for the road agin in almost 8 yearsi am thinking about taking ing it to a mechanic butr i am wondering what should be done regarding a tune up like what things would needed to be checked or adjusted or replaced? the motor is a 300 inline 6 with a 1 bbl carb and new air filter and oil filter ..thats it any help i really appreciate!!!
  #2 (permalink)
Old 07-01-2009, 08:42 PM
flipklos flipklos is offline
flipklos is starting off with a positive reputation.
Plugs, wires, rotor, cap, fuel filter.
Add to that a coolant, trany, and gear lube change and you sould be in fair shape.
A good carb and timing tune helps too,
  #3 (permalink)
Old 07-02-2009, 10:19 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
1981 Ford Bronco
AbandonedBronco is starting off with a positive reputation.
Another thing to check for is vacuum leaks. After sitting for 8 years, you may start running into brittle gaskets that will let in air. The ones I ran into issues with when freshening up my 300 after sitting for 4 years were the base gaskets underneath the carb. They're cheap and easy to replace, but when they cracked all the way, my engine wouldn't idle under 3000 RPMs and I had to use the brake instead of the gas to control the speed of the truck until I got home.
__________________
4bbl Holley 390 w/ Offenhauser DP intake. 4 speed Manual w/OD. K&N air filter, EFI manifolds, 2.5" exhaust.
3.00 rear end and 2000 RPMs @ 80mph!
Boise, Idaho
  #4 (permalink)
Old 07-02-2009, 12:39 PM
2003 Ford F-250
My Garage
awesome thanks guys
  #5 (permalink)
Old 07-02-2009, 08:36 PM
I would also recomend you pack your front wheel bearings, and do a full chassis gresse job. Check for bad U joints, tie rods, and the like.
Abandoned is got a good add on too. Hope she treats you well.
  #6 (permalink)
Old 07-02-2009, 10:42 PM
2003 Ford F-250
My Garage
yeah i was plannin on doin that got to get on it
  #7 (permalink)
Old 07-03-2009, 10:32 AM
Harte3 Harte3 is online now
Harte3 is starting off with a positive reputation.
http://www.ford-trucks.com/forums/86...ap-on-efi.html
abelmoreno's list of quality tune-up parts.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
  #8 (permalink)
Old 08-31-2009, 11:33 PM
mybrownie's Avatar
mybrownie mybrownie is offline
mybrownie is starting off with a positive reputation.
I too am getting a tune up and searching for parts. I think most of my parts are stock...anyway, I was wondering about the brand of spark plug wires and which spark plugs to use. Also, which coil is best...it's a daily driver.
Thanks
  #9 (permalink)
Old 09-01-2009, 12:43 AM
Gramps86 Gramps86 is offline
Gramps86 is starting off with a positive reputation.
not the oldest post relived, sweet haha.
seem to see alot of luck running autolite plugs, and unless your truck is 98 or newer (which i know it isnt otherwise you wouldnt be here) stay away from platinum,titanium, or whatever other fancypants plug they try to get you to get at the parts store. these older trucks werent designed for them and dont run a spark (stock replacementwise) strong enough to utilize their potential. plug wires, you can run autolite wires, or napa's belden, or if you want get the accel ones. whatever way you go, get the better wires, they last waaaay longer than the cheapies. as for the cap and rotor, make sure its got the brass contacts, NOT aluminum meaning get the good ones.
  #10 (permalink)
Old 09-01-2009, 12:22 PM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
i just did a tuneup on my truck a couple thousand ago. my list was...
autolite copper plugs
taylor 8.2mm streetfire wires
accell cap and rotor
msd coil
i got all the parts off of summit or jegs...i cant quite remember... another thing is to check all of your gearbox's, fluids, and if you are able to double check the timing...why not.. and dont forget to lube up that chasis!
__________________
FORD......Found Off Road Diggin......
Quote:
Originally Posted by 6CylBill View Post
The only way this Bronco could get any better is if Jessica Alba and Lindsey Lohan made love and waxed this Bronco with their combined love juices.
Tags
49 , autolite , belden , daily , driver , engine , ford , good , inline , parts , plug , plugs , spark , tune , wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
