Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 10:09 PM
Green_Monster Green_Monster is offline
Green_Monster is starting off with a positive reputation.
Question fried alternator wire abd possible upgrade
tried starting my 70 with a390 today and the ground wire from my alternator to radiator support melted. I do not think any wires are crossed my thought is alternator is fried. Its to late to find out for sure.
Also if its fried looking for a quality upgrade to a single wire higher amp model.
any thoughts on either is appreciated
__________________
1995 F250 4x2 reg Cab Long Bed 351 e4od 4.10ls Farm Truck
2008 Honda Ridgeline RTS Daily Driver for my business
2001 Chevy Silverado 1500 ec/sb 4x4 Z71 - wife's horsey hauler
  #2 (permalink)
Old 06-30-2009, 11:28 PM
dbdbb dbdbb is offline
dbdbb is starting off with a positive reputation.
Are Your battery to ground and engine to ground cables hooked up and in good shape? The only time I've seen the Alt. ground wire fry was when the only path to ground for the starting circuit was through that small wire. I suggest checking to make sure You have a good clean battery cable from the negative battery post directly to the engine block or one of the starter bolts, and a good clean cable from engine to chassis (like the one that fried).
  #3 (permalink)
Old 07-01-2009, 06:44 AM
brand new batt cables and replaced the ground wire that fried and tried again? I will check the grounds again but the 2 that you mentioned should be OK
__________________
  #4 (permalink)
Old 07-01-2009, 11:39 AM
Madathlon's Avatar
Madathlon Madathlon is offline
Madathlon is starting off with a positive reputation.
Should have, Batt to Block, Block to cab and Batt to Body. Now the alt one will only melt for 3 reasons, Other grounds have gone bad. The (+) from the alt to the harness has rub thru the (-) and grounded out. Or Your cables are on backwards and you back feed the circurt. (Highly Unlikly)
__________________
If it ante broken dont fix it.. If it is.. hit it with the biggest hammer U can find :P
  #5 (permalink)
Old 07-01-2009, 09:36 PM
ok checked wiring but did not remove alt yet. Its been freaking raining here for a month.
All wiring is correct, I am suspecting bad ground or corroded one. I would rather get a single wire Gm in a ford case as I have seen in magazines and supply houses. What are your thoughts any better brands than another?
__________________
  #6 (permalink)
Old 07-01-2009, 09:47 PM
Madathlon's Avatar
With the Cold you get in Mass, a one wire should do well. If you go with a one wire, try to get at lest one tahst 100 amps and a new Battery to go with it
__________________
  #7 (permalink)
Old 07-01-2009, 10:09 PM
battery is new and load test excellent. Looking at a 100 or 140 amp alt for future considerations
__________________
  #8 (permalink)
Old 07-01-2009, 10:13 PM
Madathlon's Avatar
Sounds like your on a good path. and rememeber, you can NEVER have enough grounds
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
