Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 09:40 PM
Bustnbig2's Avatar
Bustnbig2 Bustnbig2 is offline
Bustnbig2 is starting off with a positive reputation.
intake manifold leak
On the way home the other night The choke heating tube on my 460 blew out of the intake manifold. when I looked at it it had two gaskets and a bunch of sealer under it so I assume this happened to the previous owner as well. I put a new carb with a strait electric choke on it so I don't need the tubes. Does anyone have an idea as to how I can get this to seal an not come back off? Before I could get stopped the heat from the leak fryed a couple of hoses and melted part of the carb, so I never want this to happen again.
  #2 (permalink)
Old 07-02-2009, 12:20 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is starting off with a positive reputation.
couple of ways.
you can get a block off plate that goes between the intake and head that blocks this cross over port off. Felpro makes and intake gasket that includes this tin block off plate as it is used in propane apllications.
if i remember correctly, the tube slips into this port so you could drill and tap it to fit a plug or bolt to seal it off. that would probalby be the easier option.
rgds
Mike
Tags
f150 , ford , gasket , intake , leak , manifold
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
