Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 06:42 PM
gilllawn gilllawn is offline
gilllawn is new and has a neutral reputation at this point.
Cam / Lifter Assembly Help
I have a 77 351m motor that I want to put an RV cam in so it has some really good low end torque. It doesn't need to be wild or crazy. It will be a daily work truck and would pull a 16ft trailer. I would prefer not to modify the push rods or heads with the excepction of maybe upgrading the springs. Any ideas on what to get????
  #2 (permalink)
Old 06-30-2009, 07:45 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
You should always use the matched springs for the cam. You will need to check lifter preload. Most aftermarket cams have a different base circle so you may need different length push rods. Sometimes you can get away with just shimming the rocker stands.
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 06-30-2009, 07:49 PM
I noticed that some sets come with LIfters and the cam and some sets with lifters, cams and springs. How would you know what needs modified? Where do you get the new pushrods from?
  #4 (permalink)
Old 07-02-2009, 10:27 AM
mark a.'s Avatar
In general, you would put the #1 cylinder's valve train in with light checking springs on the valves. Get the preload set right then check how the rocker tip is sweeping the valve tip. Then you will know if you need a different length push rods. Summit Sells push rods & length checkers.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
