Click...click...click
'84 F250, 351W. several times over the past week I have had a little trouble with starting the engine. Most of the time it started strong, but several times it was slow to turn over. Now its just going click, click, click. I found that i had a loose connection at the battery so i tightened it and charged the battery. Then it double clicked, but the gauge on the battery charger showed the charge went from 100% to 10% almost instantly. I tried to use another vehicle and jump it with cables, but no good...clik, clik, clik. I checked the ground connection at the engine block and it is loose also, but the stud just spins around without tightening. I'm hoping the starter wont have to be replaced, but where should I go first?
I had that problem once but, as it turned out, the engine wasn't turning because
the crankcase had filled with gasoline.
https://www.ford-trucks.com/forums/7...crankcase.html
You know what it finally was? The battery cables. The positive cable was corroded under the insulation about two inches up from the battery connector, which I'm pretty sure was preventing enough juice from reaching the starter.
It might be worth your while to check those cables. Mine had corroded to pale green powder in some places.
Oh, I should mention that removing starters is especially fun lying on your back on asphalt in cold, pouring rain.
Good luck!
Ford Goblin
25
07-21-2015 11:44 PM
srqdiesel chef
02-25-2014 12:08 PM
12valveEx
08-16-2013 08:24 PM
eddie v
12-07-2010 04:27 PM
