Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 07-03-2009, 10:51 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
Manual glow plugs, as far as after glow to keep it running, that is for temps below 10 degrees.
When you get in the minus temps, more than once may be required if it starts stumbling.
Above 30 degrees, mine never stumbles once fired.
As I read through this all, I wonder what the fuel level in the tank is.
A cracked pickup tube in the fuel tank can cause symptoms like that at levels below 1/2 tank usually.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #32 (permalink)
Old 07-04-2009, 01:07 AM
wreckinball's Avatar
wreckinball wreckinball is offline
1994 Ford F-350
wreckinball is starting off with a positive reputation.
sounds good tomorrow is the day! i just need to know how to rotate the engine so i can locate the allen screw!
__________________
94 F350 Extra Cab 7.3l IDI NA W/C6. Major mod is the F150 Body(LMAO) my truck makes me laugh and everyone else scratch their heads!
BC Chapter Member
  #33 (permalink)
Old 07-04-2009, 01:09 AM
1994 Ford F-350
Ahh i didnt think of that one, not a common one but definitely possible!
__________________
BC Chapter Member
  #34 (permalink)
Old 07-04-2009, 01:35 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Use a 15/16" (IIRC) socket on the crank bolt or bump it over with a remote starter.
I bump it! Just be quick on the bump once close. It doesn't have to be perfect, just close enough to gain access to the adjuster.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #35 (permalink)
Old 07-04-2009, 01:48 AM
1994 Ford F-350
-Enjoy
fh : )_~
With the bump, is is safe for the relay to "arc" the starter relay to achieve the bump or just use ignition??
__________________
BC Chapter Member
  #36 (permalink)
Old 07-04-2009, 02:07 AM
Jump from the input side (battery side) of the solenoid to the energizing (S) terminal, It's a small arc and will hurt nothing.
Do not go from the input terminal (battery side) to output terminal (starter side), To many amps causing mucho sparks and melting!
-Enjoy
fh : )_~
__________________
  #37 (permalink)
Old 07-04-2009, 07:34 AM
Glockem45's Avatar
Glockem45 Glockem45 is offline
Glockem45 is starting off with a positive reputation.
Thumbs up
I keep the tanks full so as not to let moisture to build up in the tanks. I'll keep looking around I guess.
__________________
1985 F-250 XL 4x4 6.9L Diesel 125k Original Miles
1955 F-250 I-6 223 123k Original Miles
Tags
2000 , 73l , bad , blowing , bypass , diesel , f150 , ford , forums , glow , idi , module , plug , ruff , running , runs , smoke , truck , warms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
