Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 07-02-2009, 10:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1986 Ford F-250
Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all Dave Sponaugle is a name known to all
The electrical connections only iluminated the water in fuel light when water was present in the seperator and had reached a predetermined level.
The fact the seperator is still inline is enough for air intrusion.
Many people have had sucess just shoving a bolt in the drain line after they drain it.
Mine was letting air suck in around the pull ring shaft, so the bolt did not help.
Removing it from the truck took care of the problem though.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #17 (permalink)
Old 07-02-2009, 11:36 PM
wreckinball's Avatar
wreckinball wreckinball is offline
1994 Ford F-350
wreckinball is starting off with a positive reputation.
Damn now i am glad i dont have one in the truck, one more thing to remove and toss in the garbage!
__________________
94 F350 Extra Cab 7.3l IDI NA W/C6. Major mod is the F150 Body(LMAO) my truck makes me laugh and everyone else scratch their heads!
BC Chapter Member
  #18 (permalink)
Old 07-03-2009, 12:24 AM
1986 Ford F-250
Wreckinball, the water seperator I was talking about was on the 86 and earlier trucks.
In 87 they went to the water seperator/filter combined unit which works much better.
I know yours is a mut, but which fiter system do you have?
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #19 (permalink)
Old 07-03-2009, 12:29 AM
1994 Ford F-350
Oh come on now Dave, you know i dont have one! I am a rebel. I have a racor with the bottom separator on order and it should be here soon so we will see. It was funny too i looked for the longest time finally coming to the realization that i dont have one! hahaha. Probably help with the starting and overall operability. Thoughts on that?
Oh and please reply to this just real quick then we can get back on topic.
Why would i have a drop of oil on the tip air filter assembley bolt? It is always there and might explain why it smokes a bit! I dont have the knowledge to pull all of that off to check it, help bro!
__________________
BC Chapter Member
  #20 (permalink)
Old 07-03-2009, 12:16 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Wreckingball, Service your CDR or replace if failed.
CDR Test procedure
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #21 (permalink)
Old 07-03-2009, 06:56 PM
1986 Ford F-250
The CDR is where the oil is from.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #22 (permalink)
Old 07-03-2009, 07:03 PM
1994 Ford F-350
whew, well three blisters and a sore back later i got it out, cleaned and back in. All of the smoke i burned off with a trip down the road but now i see my beasts true colors. I think the pump is turned up too high because it is some blck smoke coming out now and not blue. I really dont want to crack the IP open but i may just have to. Can you fellas link me to the instructions on that one, the search function is killing me!
__________________
BC Chapter Member
  #23 (permalink)
Old 07-03-2009, 07:40 PM
I can't find a link, but it's easy...
On the passenger side of the IP is a triangle plate with 2 bolts.
Place a rag or something under it to catch the fuel when you remove that cover. (~1 pint) (~ (tilde) = Approximately)
Look through the cover and rotate the motor until you see the adjustment screw (I believe it's TDC #1).
With a 5/32" allen wrench turn the screw in for more, out for less.
Use the flats of the allen to track changes... ie: 1/2 flat, 1 flat... etc...
Replace the cover and test run!
-Enjoy
fh : )_~
__________________
  #24 (permalink)
Old 07-03-2009, 07:50 PM
Glockem45's Avatar
Glockem45 Glockem45 is offline
Glockem45 is starting off with a positive reputation.
Thumbs up
Ok. I checked and changed my fuel filter today. When I removed the filter is was completely full. So I guess I am not getting air intrusion after all, at least enough to make any difference at the fuel filter. Any other ideas what would make it essentially starve for fuel after 5 seconds of running?
__________________
1985 F-250 XL 4x4 6.9L Diesel 125k Original Miles
1955 F-250 I-6 223 123k Original Miles
  #25 (permalink)
Old 07-03-2009, 08:03 PM
That was after setting all night???
Hmmm...
Are you after glowing your manual GP's???
-Enjoy
fh : )_~
__________________
  #26 (permalink)
Old 07-03-2009, 08:07 PM
Glockem45's Avatar
Thumbs up
Yes, the truck sat for about 12-14 hours over night, and the filter was chock full of fuel.
No, I am not afterglowing the plugs. I guess I could do that, or hold the GP's on just a little longer, perhaps 8 seconds in the summertime.
__________________
  #27 (permalink)
Old 07-03-2009, 08:17 PM
If it starts quickly your initial times may be fine, however you likely do need to after glow a couple time for a few seconds.
Someone with a manual setup could answer that better, I know my '86 does it when it needs it! Before or after starting.
-Enjoy
fh : )_~
__________________
  #28 (permalink)
Old 07-03-2009, 08:42 PM
1994 Ford F-350
my manual set up is simple, hold for 5 seconds and turn it over for two to three seconds, it wont start the first time. glow again for three to five seconds and kaboom it is alive and well. no need for after glow. I love my beast!!!
__________________
BC Chapter Member
  #29 (permalink)
Old 07-03-2009, 08:51 PM
1994 Ford F-350
-Enjoy
fh : )_~
Well if that is all there is to it then i might try. I have rewired the GP's and installed a manual switch, serviced the CDR, re done the intake, etc etc, i just need to do it and stop worrying. so for rolling the engine, socket on the main pulley? and for turning the fuel down.......clockwise or counterclockwise? When i turn it down, how will i know when it is good but enough to keep it alive? Will i notice a loss in power? Right now it is quick for a three ton beast non turbo'd. If i threw on a turbo i would be killing the road!
__________________
BC Chapter Member
  #30 (permalink)
Old 07-03-2009, 09:43 PM
I have faith ... You can do it!
In = CW = More Fuel.
Out = CCW = Less fuel.
Back if off till it quits smoking black. I'd say 1/2 to 1 flat to start with.
Don't worry about backing it off to far, nothing bad will happen other than it will loose power, but that'll take more than a flat or two below black smoke.
When turning up a Diesel, once it starts smoking black you are doing nothing but wasting fuel. So just under black smoke is where you want to be!
Vapor Trails is all you should see.
-Enjoy
fh : )_~
__________________
Tags
2000 , 73l , bad , blowing , bypass , diesel , f150 , ford , forums , glow , idi , module , plug , ruff , running , runs , smoke , truck , warms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
