Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 04:28 PM
david67's Avatar
david67 david67 is offline
1967 Ford F-100
david67 is starting off with a positive reputation.
67 f100 tranny question
I have a 67 F100 with the original 352 FE. What, if any, modifications do I need to make to change from a 3-speed in the floor to a c4 or c6 automatic?
  #2 (permalink)
Old 06-30-2009, 06:26 PM
dbdbb dbdbb is offline
dbdbb is starting off with a positive reputation.
Welcome to the forum, You'll need a trans. with torque converter, trans. cooler, auto trans shifter, flex plate instead of flywheel, and drive shaft modification. If anyone else has something to add please chime in. A good way is to find a donor truck with a FE engine for parts. Dan
  #3 (permalink)
Old 06-30-2009, 07:34 PM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
David, I don't think there are any C4s with a FE bells but there are a ton of C6s available. I might suggest that you look at a 73-76 F-series as a donor. The truck C6 has a different shift arm from the car.
A 73-76 truck donor could provide you with tranny, disc brakes, and power steering, steering column.
You will also have to remove the pilot bushing from the end of the crank to use a C6.
guluk
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #4 (permalink)
Old 06-30-2009, 09:56 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Freightrain is gaining momentum as a positive member of FTE.
Welcome aboard david67.
There actually IS an C4 available, but it's usually only made for racing. Lots of drag racers are running them, but they aren't cheap as it takes a high dollar bellhousing to convert it to fit an FE.
Like John says...get a later model truck and get lots of other goodies for yours.
__________________
*signature delete option*
  #5 (permalink)
Old 06-30-2009, 10:48 PM
david67's Avatar
1967 Ford F-100
Thanks
Thank you everyone....anyone hear of a cheap donor, please let me know...thanks
  #6 (permalink)
Old 07-01-2009, 06:26 AM
jowilker's Avatar
1966 Ford F-100
Keep an eye out in your local Craigslist.
John
__________________
  #7 (permalink)
Old 07-01-2009, 11:02 AM
david67's Avatar
1967 Ford F-100
Thanks, will do...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
