Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 04:21 PM
Tom D Tom D is offline
Tom D is starting off with a positive reputation.
Diaphram Pump
I recently purchased a Jabsco Model 31801-1305 diapram pump. It worked great for moving my bio around. Lately it is almost impossible to prime and pumps slow. I suspect it has nitrile diaphram and valves in it. The parts breakdown shows there is vitron parts available for it but I have been unable to contact any suppliers for it.
Any suggestions?
Tom
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #2 (permalink)
Old 06-30-2009, 07:17 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
Biodiesel Guru
fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold
Quote:
Any suggestions?
Tom
Try here Tom: http://www.jabsco.com/distributor_lo...a-state-FL.htm
__________________
FABMANDELUX.
Don.
Oregon Chapter Leader: To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 06-30-2009, 10:30 PM
Thanks Don
I got into their catalog but didn't have any luck with viton so I'll call and see if they're available.
__________________
  #4 (permalink)
Old 07-22-2009, 04:01 PM
Quote:
Originally Posted by fabmandelux View Post
Well..so much for that plan. I can't replace the diaphram and valves on that pump (Jabsco 31801-1305) with oil resistant. Hell, I can't even replace them with OEM. I guess Jabsco doesn't manufacture that model any more. What a waste of money that was.
__________________
  #5 (permalink)
Old 07-22-2009, 08:28 PM
Rushmore X Rushmore X is offline
Rushmore X is starting off with a positive reputation.
Hate it when that happens, go to get replacement parts and they are no longer made. Had a motor-tool that broke a $3.00 spring and ended up having to replace the whole tool because the spring is no longer made...
__________________
2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, more to follow! Gone BIO!!!
  #6 (permalink)
Old 08-03-2009, 09:33 AM
DeepRoots DeepRoots is offline
DeepRoots is starting off with a positive reputation.
I deal with these pumps.
Go look at Graingers and or McMaster Carr.
They'll find something for ya.
__________________
'89 Ford F250 7.3 Diesel, used to be c6 I stuffed a zf5 in there now, ATS 088 turbo, 3.55rear, 2wd. Moosepump
  #7 (permalink)
Old 08-03-2009, 07:33 PM
Tks, I'll check it out.
__________________
  #8 (permalink)
Old 08-10-2009, 07:32 PM
I'm not 100% on your type of pump, but with any pump of this type, don't deadhead it if you can help it, and if it has check balls on the suction side, make sure they are seating well.
Most times these pumps are condemned it is just inability to make suction, or forcing pressure through the suction side.
__________________
Tags
1999 , breakdown , e40d , parts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
