Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2010 6.4L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2008 - 2010 6.4L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 03:25 PM
chi6488 chi6488 is offline
chi6488 is starting off with a positive reputation.
Turbo Spooling
I have noticed my turbo is spooling a lot. I think that is what you call it. It sounds like a jet taking off. It seems to do it more when temps are hotter outside.
Any ideas?
  #2 (permalink)
Old 07-01-2009, 08:32 AM
stevensm stevensm is offline
stevensm is starting off with a positive reputation.
Sure that its your Turbo and not your radiator fan kicking on to cool. When the clutch engages for the fan it makes some serios noise.
  #3 (permalink)
Old 07-01-2009, 02:35 PM
trfdfirefighter's Avatar
trfdfirefighter trfdfirefighter is offline
2008 Ford F-250
trfdfirefighter is starting off with a positive reputation.
thats def the fan. unless you have a large aftermarket intake/exhaust or upgraded turbos you hardly ever really hear them spool like on other diesel engines. these trucks have quiet turbos, definitley a bummer.
  #4 (permalink)
Old 07-13-2009, 11:45 AM
It is not a fan. It kicks on when motor is still cool after sitting 8 hrs at work. The noise increases with higher rpms
  #5 (permalink)
Old 07-13-2009, 01:10 PM
sawtooth's Avatar
sawtooth sawtooth is offline
sawtooth is starting off with a positive reputation.
Still could be the fan. There is a sensor or something that can go bad and cause this issue. My truck does this if its hot and sits in the sun then i crank it up. It starts when i apply throtlle then ends after 20 seconds or so. It is very loud and sounds like a jet taking off and increases with throttle. You may have a bad thermostat.
__________________
01 Supercrew 4x4, 5.4 eng, 160K Awesome Truck
08 Dark Stone F250, 6.4, 3.73, 4x4 Lariat, Job3
ATS Color Matched Street Flares
Eaton Elocker "front" / Truetrac Limited Slip "rear"
Banks Ram Air Intake
Spartanized 75, 150, 210HP
  #6 (permalink)
Old 07-13-2009, 04:01 PM
2008 Ford F-250
could be thermostat, bad fan motor, a few things can cause fan to stick on. if your turbos were making that much noise you would have to have a hole in pipe or ur intake slipped off the turbo inlet which would def throw a code on the truck.
  #7 (permalink)
Old 07-18-2009, 09:12 AM
F450OldGuy F450OldGuy is offline
F450OldGuy is starting off with a positive reputation.
You guys have me thinking now. I have the same issue and I thought it was the turbo spooling also. It doesn't happen all the time, and doesn't only happen when it's hot. At times it happens within the first few minutes of the truck being started. It seems to happen more when I have a load on the truck putting it up a grade. The power is like it almost cuts way back. It seems to help if I back out of it. I took it into the dealer and they are telling me everything checks out fine. So you guys are saying this might just be a thermostat issue?
  #8 (permalink)
Old 07-18-2009, 08:43 PM
2008 Ford F-250
yeah because under a load especially uphill the ect and eot and egt's go way up causing heat issue and loss of power with the fan motor running hard to try and fix it. also when the truck is first starting the motor is cool so the fan motor shouldnt be running like that which a thermostat issue can cause
  #9 (permalink)
Old 07-18-2009, 09:54 PM
Crazy001's Avatar
Crazy001 Crazy001 is online now
2008 Ford F-250
Crazy001 has a good reputation on FTE. Crazy001 has a good reputation on FTE.
Quote:
There is NO FAN MOTOR on these trucks! The fan is driven off of the drive belt, just the same as it is on nearly every other truck! The difference is that this one is electronically controlled rather than a mechanical heat-operated one.
Quote:
Originally Posted by Ford Service Manual
the actuator valve controls the fluid flow from the reservoir into the working chamber. Once viscous fluid is in the working chamber, shearing of the fluid results in fan rotation. The valve is activated by a pulse width modulation (PWM) output signal from the PCM. By opening and closing the fluid port valve, the PCM controls the fan speed. Fan speed is measured through a Hall effect sensor, and is monitored by the PCM during closed loop operation. The PCM optimizes the fan speed based on the engine coolant temperature, the engine oil temperature, the transmission fluid temperature, the intake air temperature, or air conditioning requirements. When an increased demand for fan speed is requested for vehicle cooling, the PCM monitors the fan speed through the Hall effect sensor. If a fan speed increase is required, the PCM outputs the PWM signal to the fluid port, providing the required fan speed increase. During the key on, engine running (KOER) self-test, the PCM commands a 100% duty cycle. A DTC is set if the PCM detects the voltage on the valve control circuit is not within the expected range or if the fan speed is less than a calibrated value.
Key on, engine running self test is what you are hearing when you start your cold truck on a cold morning. 100% duty cycle means that the fan is spinning as fast as the water pump pulley is. The fan will also come on if the PCM determines it's needed to move air through the A/C condenser to cool your cab down. This fan clutch is capable of spinning the fan as fast as it wants, up to the speed the engine is spinning the pulley...
__________________
Tom,
Current truck - 2008 F250 CC 4x4 PSD
Previous Fords:
2007 F150 Screw 4x4
2003 F150 4x4 r/c auto
  #10 (permalink)
Old 07-18-2009, 11:03 PM
Most of the time I will back out of it when it happens. That seems to help a bit. I've had it into the dealer two times now for this issue and they keep telling me they can't find anything wrong with the truck. I think now that it might be a heating issue I can go back in and have them check it out. If they plug it into the computer will something show up? It would be so nice to fix this issue.
  #11 (permalink)
Old 07-19-2009, 12:04 PM
Crazy001's Avatar
2008 Ford F-250
Oldguy, did you read my post?
When it kicks on, is it at low speed with the A/C on? My work truck does this, and it drives me NUTS! Of course, my work truck is way bigger than a super duty, and the cooling fan sucks nearly 75 HP to turn, which makes for slow going getting back up to speed again. To avoid it, I switch off the A/C when I'm going slow.
Our Super Duties do the same thing...it's simply to provide you with a/c on hot days. Without air flow through the condenser, there IS NO A/C...therefore when you're going slow it kicks on the fan simply to get your A/C going...
__________________
Tom,
Previous Fords:
2007 F150 Screw 4x4
  #12 (permalink)
Old 07-19-2009, 12:24 PM
It just doesn't do it when the A/C is on. It even happens in the winter when it's not real hot outside. This is why i'm wondering if it's more then just the fan.
  #13 (permalink)
Old 07-19-2009, 07:18 PM
jrtraderny jrtraderny is offline
jrtraderny is gaining momentum as a positive member of FTE.
I've been told ( not sure if it's true) that when cold or light load the fan turns on to work the engine to bring it up to temp faster.
jr
  #14 (permalink)
Old 07-21-2009, 08:09 AM
waverunner800 waverunner800 is offline
waverunner800 is starting off with a positive reputation.
Mine sounds like an F-4 Phantom when I first take off when it's cold. Goes away after about 400 yards and sounds fine....
  #15 (permalink)
Old 07-24-2009, 11:46 AM
Quote:
Does it also cut the power way back on it?
Tags
f250 , loud , spool , spooling , turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
