Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 02:01 PM
95 F150 Dude 95 F150 Dude is offline
95 F150 Dude is starting off with a positive reputation.
4.9 Lightning
Guys,
I have access to a complete first Gen Lightning and would like to pull the suspension out and install it on my 95 short bed to make a 4.9 Lightning
My question is what components do I need? I know the sway bars are larger. The front springs are shorter. The rear springs are different and the rear shackles are different. Anything else I'm forgetting?
Scott
  #2 (permalink)
Old 06-30-2009, 02:16 PM
jas88's Avatar
jas88 jas88 is offline
jas88 is gaining momentum as a positive member of FTE.
"4.9" and "Lightning" are 2 terms I did not think I would see used together as a phrase.
__________________
1991 F150 SuperCab 4.9L/ZF5
1991 Bronco SAE 5.0L/E4OD
2005 Escape 2.3L/CD4E
  #3 (permalink)
Old 06-30-2009, 02:19 PM
Jason Lewis's Avatar
Jason Lewis Jason Lewis is offline
1996 Ford F-150
Jason Lewis is gaining momentum as a positive member of FTE.
Whats wrong with the Gen 1? is it driveable?
Other wise if it is why the hell would you strip a gen 1 !!!!
Oh the other hand if its totaled then the springs front/rear would install no probs strait bolt in.
Use the gen 1 rear spring shackels to,
I did this swap on my 96-(303) no probs
check my gallery
__________________
1996 F-150 Lightning Clone Look in My gallery
"Pushrod all the way"
http://www.youtube.com/watch?v=kp4c_fCu3FI
  #4 (permalink)
Old 06-30-2009, 03:41 PM
Thanks for the response. The owner says it's been hit and totaled so he is parting it out. He wantes to keep the motor and trans but the rest is up for grabs. I will post what I don't get on here if anyone is interested.
Anything else other than the springs, shackles and sway bars?
Scott
  #5 (permalink)
Old 06-30-2009, 03:44 PM
Jas88,
I didn't think I would ever do anything like this either. But I like the idea of a classsic, well handling F150 that gets 20 MPG
  #6 (permalink)
Old 06-30-2009, 04:11 PM
1996 Ford F-150
Cool, yea take the seats to that would be a great upgrade!
__________________
  #7 (permalink)
Old 06-30-2009, 04:22 PM
6CylBill's Avatar
6CylBill 6CylBill is offline
1994 Ford F-150
6CylBill has a good reputation on FTE. 6CylBill has a good reputation on FTE.
This is a great idea! I love it! I just talked to a guy the other day with a 4.9L FlareSide sitting on Lightning suspension and rims. LOOKED AWESOME.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #8 (permalink)
Old 06-30-2009, 04:42 PM
lew52's Avatar
lew52 lew52 is online now
lew52 is gaining momentum as a positive member of FTE.
Sounds good , just check everthing out, you don't want anything thats bent . Its hard to tell sometimes . When a truck is totaled the suspension ussally takes a good hit . Good luck, there might be all kinds of goodies you can get .. Lew
  #9 (permalink)
Old 06-30-2009, 05:25 PM
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
dont forget the 120mph speedometer., you should be able to make it work.
ive always said, if you worry about gas mileage you arent having fun.
__________________
  #10 (permalink)
Old 06-30-2009, 05:27 PM
1996 Ford F-150
Quote:
I want to see that thats gotta be awesome !
__________________
  #11 (permalink)
Old 06-30-2009, 05:33 PM
andym's Avatar
andym andym is offline
1989 Ford F-150
My Garage
andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future andym has a brilliant future
If the front springs are shorter, they will throw the camber off and you might need new alignment bushings. I'm not sure if lightnings had different bushings or not or if Ford did it another way.
__________________
Andy
Quote:
Nothing is obscene if we only close our eyes
  #12 (permalink)
Old 06-30-2009, 06:46 PM
Thanks for the encouragement guys. The guy I'm getting it from wants the motor, trans and A/C parts which I don't care to get. The only items missing are the rims and gauge cluster. The rims I can live without because I wanted to go with newer Lightning rims anyway. The missing gauge cluster is kind of a bummer though.
Scott
  #13 (permalink)
Old 06-30-2009, 06:49 PM
6CylBill's Avatar
1994 Ford F-150
Quote:
It would be, if it wasn't in two different colors and the rear end wasn't smashed in! The truck had a LOT of potentianl though. All it needed was a paint job, tailgate, and rear fiberglass where the truck rear ended him.
I was in love with the stance though. When I seen the truck it made me regret not doing the same to mine.
__________________
GodBlessAmerica!!
GodBlessFTEUsers!
'94 F-150 FlareSide
  #14 (permalink)
Old 06-30-2009, 10:21 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
There is no difference between a f150 spring shackles and lightning ones. The seats are a nice addition
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #15 (permalink)
Old 07-01-2009, 02:50 PM
trk98 trk98 is offline
1989 Ford F-150
trk98 is starting off with a positive reputation.
Whats stopping you from getting drop beams? Are they much different, better/worse than lightning ones? Whats different from a typical truck? Are spindles and brakes different?
Tags
95f150 , clone , f150 , ford , forums , lightning , pickup , rim , sale , texas
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
