Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 01:31 PM
oldfordcoupe oldfordcoupe is offline
oldfordcoupe is starting off with a positive reputation.
question?
i have a 460 that i could build for my 65 but i don't know what type of tranny to put behind it ? if its and auto what will work ?? any ideas mabey a little help
  #2 (permalink)
Old 06-30-2009, 02:51 PM
banjopicker66's Avatar
banjopicker66 banjopicker66 is offline
banjopicker66 is gaining momentum as a positive member of FTE. banjopicker66 is gaining momentum as a positive member of FTE.
I have a 460 in my '66, converted it form a 352 with a 3 speed originally.
As for the 460, it is such a great engine from the start that if you build it to 1970 specs, and use all stock parts, you'll have almost more than the truck can handle!
As for a transmission, the C-6 automatic is probably the best overall. The C-5 can be built to handle it but for ease, simplicity and lower cost, the C-6 doesn't get any better.
The most important thing to consider is this: Get the factory Ford engine perches from a '73 - '79 which came with the 460. They will properly align the driveline for best and proper fitment. The 460 sits nicely in these trucks, but put in improperly it will be an unpleasant problem to fix the fitment.
Other considerations:
Is the truck a 6? You will need V-8 springs and a V-8 radiator.
Disc brakes to stop the heavier truck safely
Power steering is very helpful! - but requires steering column changes, as well as the brackets and PS pump on the engine.
Get yourself a donor truck that has a 460, even if it doesn't run. Having all the little nitnoid parts right at hand as you do the swap will make the swap an enjoyable one, and will really reduce the frustration.
__________________
1966 F-100 460, C6, power disc brakes, power steering
2000 F-250 SuperDuty 7.3L Diesel 150K, pillar gauges, oil drain valve - Infected with PMS.
He is no fool who gives up what he cannot keep to gain what he cannot lose! (cf Mt 16: 25, 26)
Deo Vindice!
  #3 (permalink)
Old 06-30-2009, 02:56 PM
As for the specific C-6, be advised that you need one that was behind a 460 or 429. The bellhousing is cast as part of the entire case into the shape of the block, so you cannot use just any C-6.
C-6 transmissions from a 351W, 302 or other engines will not mate to the 460.
__________________
Deo Vindice!
  #4 (permalink)
Old 06-30-2009, 03:57 PM
thanks for the info i new a c6 would work but not about the c5 i haven't fooled with a big block in a long long time its all been winsor motor the last 25 + years i'll start looking around thanks again
  #5 (permalink)
Old 06-30-2009, 11:19 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a good reputation on FTE. garbz2 has a good reputation on FTE.
a C6 can also be sourced from any 351M/400 equipped truck. Also a AODE can be sourced from 88 to 96 F250 equipped with a 460. Ambulances are also a good source fro these.
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive 410, C6.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
  #6 (permalink)
Old 07-01-2009, 01:35 AM
ki0cn's Avatar
ki0cn ki0cn is offline
1961 Ford F-100
ki0cn is starting off with a positive reputation.
Will the engine perches from a 73-79 also fit a 1961? I,ve also thought about a 460 swap for my uni.
Randy
  #7 (permalink)
Old 07-01-2009, 09:16 PM
garbz2's Avatar
Quote:
Randy
Randy, No as the 61 to 64 is an entirely different frame with a straight axle.
You need an aftermarket cross member and mounts. Available at most vendors that support this site. To put it in you will also need a new transmission mount available from the same places.
You will also need to remove the old bell housing mount cross member as it is no longer needed and will not allow the C6 to be removed from under neath the truck later on down the line for service.
I have 472 in my 64. The same frame rails as a 61 to 63 uni.
__________________
05 Escape XLT
  #8 (permalink)
Old 07-02-2009, 01:05 AM
ki0cn's Avatar
1961 Ford F-100
Garbz,
Thanks for the info probably still wouldn't be a bad idea tho buy a complete donor to get brackets, ECT.
Thanks Randy
  #9 (permalink)
Old 07-02-2009, 10:01 PM
garbz2's Avatar
No such thing as a donor as all the parts are aftermarket.
The front cross member is about 90 to 120 bucks
The tranny cross member is about 60 bucks
If you were going to use a FE in it i would gladly give you a FE bolt in front crossmember from the 60s.
Garbz
__________________
05 Escape XLT
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
