Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 01:02 PM
NNBD NNBD is offline
NNBD is starting off with a positive reputation.
460 Flywheel help
I have a 1975 F250 2wd 4sp with a 1978 460. The starter hits a dead spot on the flywheel every few starts so I'm suspecting a broken tooth on the flywheel. I haven't pulled the inspection cover yet. I was researching flywheels and need help in identifying what I need. I see 460 flywheels from 176 - 184 teeth, internal and external balance. How do I figure out what I need?
  #2 (permalink)
Old 06-30-2009, 08:01 PM
banjopicker66's Avatar
banjopicker66 banjopicker66 is offline
In Occupied CSA
banjopicker66 is gaining momentum as a positive member of FTE. banjopicker66 is gaining momentum as a positive member of FTE.
The 460 was internally balanced up to '79. 1980 and later 460s are externally balanced. To make sure, look for a counterweight between the harmonic balancer and the block - it will look sorta like a hatchet head.
__________________
1966 F-100 460, C6, power disc brakes, power steering
2000 F-250 SuperDuty 7.3L Diesel 150K, pillar gauges, oil drain valve - Infected with PMS.
He is no fool who gives up what he cannot keep to gain what he cannot lose! (cf Mt 16: 25, 26)
Deo Vindice!
  #3 (permalink)
Old 06-30-2009, 08:05 PM
In Occupied CSA
Check out the 460 forum here at FTE - they can give you more details!
__________________
Deo Vindice!
  #4 (permalink)
Old 06-30-2009, 11:34 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a good reputation on FTE. garbz2 has a good reputation on FTE.
The internal balance 385 series shares flywheels with the internally balanced FE.
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive 410, C6.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
  #5 (permalink)
Old 07-02-2009, 08:14 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Mid-year 1979 is when Ford changed the 460, not 1980.
The block's casting number is: D9TE-6015-AB which uses a weighted spacer. The harmonic balancer and flexplate are also different.
There is no before/after a certain serial number or production date, because this was a running change.
If the block casting number is C8VE (1968); C9VE (1969/70) or D1VE-6015-AB or AB1, or AB2 (1971-midyear 1979), there is no weighted spacer.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #6 (permalink)
Old 07-02-2009, 08:48 PM
460 Flywheel
Wow guys, that's a lot of good information. Looks like I need to get some numbers off the block. You guys rock. :}
Tags
1966 , 460 , balance , balanced , balancer , d1ve6015 , externally , flywheel , ford , harmonic , identification , internally , number , part , spacer , starter , tooth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
