Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 12:21 PM
dognip666 dognip666 is offline
dognip666 is starting off with a positive reputation.
Removing AC pulley
So I've got a 95' F-150 w/ 300 engine - the A/C has been nice and cold right along. A few days ago the A/C pulley started chattering and you could smell it burning up so I shut it off and limped along with this worsening rattle. I bought a shorter belt to bypass the A/C but it's pulley protrudes into the path of the shorter belt just a bit - can I remove the pulley from the compressor or does the whole unit need to be removed? I took the clutch off but I can't see what else holds the pulley to compressor. Any info is much appreciated.
Evan J. West
  #2 (permalink)
Old 06-30-2009, 04:23 PM
lsrx101 lsrx101 is offline
lsrx101 has a good reputation on FTE. lsrx101 has a good reputation on FTE.
Look close. There is a snap ring around the compressor snout to hold the pulley in place. Remove the snap ring and the pulley will slide off with a little help from a screwdriver.
If you need to remove the clutch coil, just pry it off with a big screwdriver working from side to side.
__________________
Oh, you drive a Hummer? Isn't that just a cute little thing!! My ride is an EMD E-8A. Wanna play chicken!
www.lakeshorerailway.org
  #3 (permalink)
Old 07-04-2009, 11:17 AM
tboss619 tboss619 is offline
tboss619 is starting off with a positive reputation.
OPPS I placed a post in the wrong place and I need to have moved to a/c repair can one of you moderators move it for me I put it in aerostar It title is clutch air- gap adjustment tks I will try harded to get my post in the rite place terry
Tags
1997 , ac , bypass , f150 , forum , pulley , reomoving
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
