Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 11:28 AM
a truck named effy's Avatar
a truck named effy a truck named effy is offline
a truck named effy is starting off with a positive reputation.
1979 302 rebuild, loctite question?
The crank shaft in my engine broke. I am replacing it and almost everything else while I have it out. My truck is a 1977 f100 ranger with a 302 engine out of a 79 Grand Torino.
I was hoping I could post here and save the trouble and time of searching all over the net for my info.
I am looking for torque specks and also wondering on which fasteners I have to use loctite?
__________________
Regards, Shaun & Effy
Shaun: 1984 Hot blooded Red blooded American
Effy: 1977 F-100 Ranger 302 2WD 3spd ManTrans
These are the last of the great trucks, lets keep them on the road guys!
  #2 (permalink)
Old 06-30-2009, 12:05 PM
Beechkid Beechkid is offline
Beechkid is gaining momentum as a positive member of FTE.
The only bolts I use loctite on are the flywheel/flexplate bolts.
fyi- I do use anti-seize on all carb/exhaust manifold studs
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #3 (permalink)
Old 06-30-2009, 01:47 PM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Cap bolts 60-70 ft/lbs
Rod bolts 19-24 ft/lbs
Crank Damper 70-90 ft/lbs
Flywheel 75-85 ft/lbs
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #4 (permalink)
Old 07-01-2009, 12:21 PM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
There's actually a link (which still works!) in the second sticky at the top of the main page which leads to a site with tightening specs. Here's the link:
http://torquespecs.tripod.com/hi_po_ford.htm
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #5 (permalink)
Old 07-01-2009, 06:36 PM
Beanscoot Beanscoot is offline
Beanscoot is starting off with a positive reputation.
I see those tables are entitled:
"High Performance Engine Torque Specifications American V6s & V8s"
I assume this is just hype, and they are stock torque values?
Also, the Hipo 289 is listed as having the same torque values for all components as the 351W, including main bearing caps and head bolts. That makes this entire table, like so much unattributed information on the Internet, suspect.
Tags
302 , loctite , rebuild
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
