Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #46 (permalink)
Old 07-10-2009, 12:24 PM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Adrenaline Junky
Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE.
IMHO = In My Honest Opinion
__________________
Horsepower = How fast you hit the wall.
Torque = How far you take the wall with you.
They say if you play a Microsoft CD backwards you hear scary messages.
Even scarier......if you play it forwards it installs Windows
  #47 (permalink)
Old 07-10-2009, 12:56 PM
goatz goatz is offline
goatz is starting off with a positive reputation.
ah lol had a brain fart this morning
  #48 (permalink)
Old 07-10-2009, 08:54 PM
Would bad injectors cause the same thing?
  #49 (permalink)
Old 07-10-2009, 11:52 PM
aslo I just did that ohm test on the injectors at the IDM plug and I am getting 2.9-3.2 ohms on all the injectors pretty much the same as when I tested right at the plugs on the valve covers
  #50 (permalink)
Old 07-10-2009, 11:54 PM
also is there any reason the #3 injector while running would have oil coming out and nothing from 1, 5, or 7? Next test I am going to do is oil pressure on high pressure galley
  #51 (permalink)
Old 07-14-2009, 04:47 PM
I was talking to a diesel tech he said possible it could be ground issue that the IDM is not grounded. where do I or where is the IDM grounded ?
  #52 (permalink)
Old 07-14-2009, 04:49 PM
fire7882 fire7882 is offline
fire7882 is starting off with a positive reputation.
Quote:
This sounds like your problem. I'm not sure the causes but you could have a bad hpop among other things. I have read that oil should be coming from all injectors.
__________________
My 1997 F450 Ambulance Project
  #53 (permalink)
Old 07-14-2009, 06:13 PM
Maybe, I do still wanna check that.
  #54 (permalink)
Old 07-14-2009, 11:57 PM
check the grounds they seem fine too
  #55 (permalink)
Old 07-14-2009, 11:58 PM
gotta make up a pil pressure tester now I guess
Tags
2 , cel , cylinder , ford , high , low , open , p0476 , p1272 , powerstroke , side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
