drrxr, he was asking about injectors and GPs so I assumed ,I know, I know LOL, he was checking them through the UVC harness. You gave him good info on the GPR though.
OK today I took off the injector harness that goes to the IDM change 2 pig tails at the driver side valve cover even thoug hthat side was fine cause it was running off that side but I did find to kind bad spot on the driver side between the front and rear clip looks like someone tired to do a fix before and glob some silcone in there so I cut that out soidered in new pig tails then I ohm tested everything everything came back good no OL so now to put that all back together.
Now can you test the solnoides on top of the injectors? what kinda ohms should I get ?
This is from Patrick Feeley
On each valve cover connection there are five pins. The outermost pins (pins 1 & 5) are for the glowplugs. They should not have continuity with each other or the center three. The center three are for two of the injectors in each bank. The ohm reading between each outermost injector(pins 2 & 4) and the center pin (pin 3) should be about 2 ohms (if I remember correctly. Pins 2 & 4 should also not have continuity with each other. The undervalvecover harnesses are just replaced as a "unit" if they are bad (there are 4 of these harnesses per truck, 2 per side). Does that help? Cheers!
__________________
Rick.......
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer".... Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
ok I think I'm going to pull out my hair now. so now I removed all the wiring on top of the motor and OHM tested it all back to the IDM everything checked out fine. So I put it all back together and passengerside is still doing nothing I can unplug the injectors and no difference it the way it runs. so I do another buzz test and now I got more codes then I had before from the buzz test.
These are the results from the first buzz test
P0267
P1272
P1274
Now my new results
p0267
p1271
p1272
p1273
p1274
p1275
p1295
ANYONE GOT ANY THOUGHTS ON IT now?
Do you have oil pressure yet?? That needs to be repaired first IMHO.
No difference when unplugged:
The IDM may be shot. It has 2 circuits, 1 for the right and left banks of the engine. Try to borrow a known good one as a substitute before buying it.
Buzz test:
The scanner you are using is suspect: You are getting Rich and Lean flags at the same time. 1274 & 1275 (Bank 2). Not completely sure though.
Just a WAG , does it start out running on 8 then drop 4 ?...
__________________
Rick.......
nope starts on 4cly, and I can see oil comming out of the #3 injector while its running. there is oil in the High pressure oil galley. Whats does IMHO mean?
