Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-03-2009, 07:04 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Adrenaline Junky
Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE.
Quote:
Originally Posted by goatz View Post
Another thing if I take out the hpop fill plug the oil is all the way up to the top is that good or bad?
Yep, that's OK.
ok i put a scanner on it and it says there is no codes but the engine light is on what gives?
The scanner is not compatible with our PSD's. If the CEL is lit, there is a code. Most of the ones you get from the mega-parts stores won't work.
__________________
Horsepower = How fast you hit the wall.
Torque = How far you take the wall with you.
They say if you play a Microsoft CD backwards you hear scary messages.
Even scarier......if you play it forwards it installs Windows
  #17 (permalink)
Old 07-03-2009, 09:42 AM
goatz goatz is offline
goatz is starting off with a positive reputation.
well now its time to find a scanner
  #18 (permalink)
Old 07-03-2009, 10:37 PM
well got a scanner on it here is the code that were stored
BUZZ TEST
P0267
P1272
P1274
Got those first before I ran it
then only got P0267 after I ran it and warmed it up.
codes i pulled out that where stored
P0563
P0603
P1280
P1661
THEN i DELETED EVERYTHING AND GOT CODE P1111
CLYLINDER CONTRIBUTION TES GOT CODES
P0263
P0269
P0275
P0281
Got some other ones too
P0195
P0476
WHAT YOU GUYS THINK
  #19 (permalink)
Old 07-04-2009, 08:46 AM
Cuda_jim's Avatar
Adrenaline Junky
Is it still running bad?
BUZZ TEST:
P0267 Injector Circuit Low - Cylinder 3
P1272 High to Low Side Open - Cylinder 2
P1274 High to Low Side Open - Cylinder 4
The buzz test is pointing to a bad #3 injector because P0267 appeared twice. It could be wiring ie. UVCH. Check that first. I would check all four UVC's connectors while you're at it.
STORED CODES:
P0563 Sys Voltage High
P0603 Internal Control Module KAM Error (typical for disconnected batteries)
P1280 ICP Circuit Out of Range Low
P1661 Output Circuit Check Circuit Low Input
P1111 Sys Pass (No DTCs Available)
All the stored codes didn't return, you got an all clear (P1111) I wouldn't be concerned with these unless they return.
CCT:
P0263 Cylinder 1 Contribution/Balance Fault
P0269 Cylinder 3 Contribution/Balance Fault
P0275 Cylinder 5 Contribution/Balance Fault
P0281 Cylinder 7 Contribution/Balance Fault
CCT can be an un-reliable test however it is pointing to a bad UVCH.
I have run the test back to back and got different results. I even ran it on a new truck and got codes for non-contributing cylinders. FYI: Both trucks were running just fine.
The EOT needs to be higher than 137ºF IIRC, before the test can be performed. That's likely where the EOT code below (P0195) came from. The engine should be screaming hot before the test is performed.
OTHERS:
P0195 Engine Oil Temperature Sensor Error
P0476 Exhaust Pressure Control Valve Range/Performance
If the scanner has the capability of watching the Parameter Identification Data (PID's) then have them checked. These are probably from the initial no-start. I wouldn't be too concerned with these unless they return or the PID is out of specs.
Here's the firing order:
__________________
  #20 (permalink)
Old 07-04-2009, 01:49 PM
awsome thanks, I did take out the number#3 injector but i did replace the valve cover gaskets and wiring and the pig tails. I will check that side out thanks jim
it is still running bad almost like its got a miss , that could be from #3 injector no?
  #21 (permalink)
Old 07-05-2009, 06:16 PM
well I took off the valve cover and inspected everything, it all looks fine. I started it up and I could only see oil coming out of the #3 injector ther was nothing coming out of 1, 5, and 7. I also unpluged the injector/glow plug harness and there was no difference in the way it runs seems like its just running off of 2,4,6 and 8. also looked to oil comming out from around the #3 injector maybe injector o-rings are gone . Oh and for all the help I have got I am now a 3 year supporter. thanks everyone for the help much appreciated
  #22 (permalink)
Old 07-06-2009, 01:18 AM
I think I am going test the wiring tomorrow
  #23 (permalink)
Old 07-06-2009, 07:47 AM
Cuda_jim's Avatar
Adrenaline Junky
If the wiring is OK the IDM is the next suspect.
Be sure to open up the large harness draped over the driver side valve cover. It's loosely wrapped with red tape.
The harness has been known to rub through wires causing all sorts of different trouble.
__________________
  #24 (permalink)
Old 07-06-2009, 10:10 AM
alright sounds like a plan, will try check that after work
  #25 (permalink)
Old 07-06-2009, 12:49 PM
Action4478's Avatar
Action4478 Action4478 is offline
taH ssA
Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE. Action4478 has a great reputation on FTE.
Quote:
BUZZ TEST:
STORED CODES:
CCT:
OTHERS:
Tried to rep ya Jim ,,but no joy ...
__________________
Rick.......
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer".... Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
  #26 (permalink)
Old 07-06-2009, 12:57 PM
I rep ya ...thanks for the help
  #27 (permalink)
Old 07-06-2009, 01:16 PM
DRRXR's Avatar
DRRXR DRRXR is offline
DRRXR is starting off with a positive reputation.
yup did that , prob going to do that a couple of times so i can clean her right out. anyone know if there is something you can put into the oil system to do a oil flush?
I found that using some cheap diesel oil from tractor supply and adding a Quart of Marvins Mystery Oil to top it off will clean out a lot of deposits after running it at 1.7K rpms for 60 miles then drain and flush with some more cheap oil. Then use the synthetic.
  #28 (permalink)
Old 07-06-2009, 01:40 PM
When you test the glows and injectors with a ohm meter is that with the ingnition on?
  #29 (permalink)
Old 07-06-2009, 03:08 PM
DRRXR's Avatar
Gpr
With key off you should have battery voltage to one large terminal and nothing on the other large post and nothing on the two small post.
With key on you should have battery voltage to both large and one small terminal for 2 minutes. The other small terminal is grounded. That indicates that the relay is active.
After the the glow plug activation is over, you should have battery voltage to one large and both small terminals.
The relay can also have bad contacts in the relay. After turning the key on (not running)check the voltage at both of the large posts on the relay. There should be very little difference in the voltage.
  #30 (permalink)
Old 07-06-2009, 03:17 PM
Cuda_jim's Avatar
Adrenaline Junky
Key off. Ohms are always checked with no power applied...might pop your meter.
2 ohms or less are good for the GPs when checked through the UVC connector.
Ohming the injectors only tests the harness under the valve covers. You have ohms or not.
__________________
Tags
2 , cel , cylinder , ford , high , low , open , p0476 , p1272 , powerstroke , side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
