Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 09:55 AM
mxhowes1 mxhowes1 is offline
mxhowes1 is starting off with a positive reputation.
Converting a TFI ignition. Any good write ups out there?
'84 E150 300. To make a long story short I want to dump my TFI for something basic and simple so I can get this van running again. I will keep it forever and won't have to worry about passing a smog test. Been searching and got some info on a few of the components but is there a write up on this project? Will I also have to change the feed back carb?
Just point me in the right direction,
Thanks,
Jim
  #2 (permalink)
Old 06-30-2009, 10:47 AM
Harte3 Harte3 is offline
Harte3 is starting off with a positive reputation.
http://gofastforless.com/ Check out the ignition section there. You can also use a DUI (Davis Unified Ignition) or a DUI DS2 system set up for your vehicle.
Nothing particularly complicated about a TFI ignition. The TFI coil is used by some as a cheap upgrade on a DS2 ignition. If everything is tuned up and adjusted properly the feed back carb is fine...that's IF. Otherwise back up to a DS2 system and an 83 or older non-feedback carb.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
  #3 (permalink)
Old 06-30-2009, 03:57 PM
PerfDistIgnition PerfDistIgnition is online now
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
Thanks,
Jim
You will need a distributor with weights, springs, and a vacuum advance to control your timing.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
fficeffice" />>>
http://performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
http://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
Ignition Lesson of the Month: Hystereses, the difference between the timing as the rpm and vacuum increases to the timing as rpm and vacuum decrease, needs to be kept to a minimum. A precise advance curve accomplishes this.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
