Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 08:57 AM
dakotajeep's Avatar
dakotajeep dakotajeep is offline
dakotajeep is starting off with a positive reputation.
Radiator Removal
Ok I am thinking about getting a new radiator. My question is what needs to be done to remove it? I understand that I need to drain the coolant. Disconnect all the hoses, shroud etc.......
But the tranny cooler lines in the lower section of the radiator, how much fluid will I lose by disconnecting those lines? I just dont want to be guessing how much tranny fluid to replace when and if I lose some when removing the radiator.
I plan to remove the fan clutch (I will rent the tool!) and replace the water pump at the same time.
Any suggestions or hints to assist me in doing this right the first time?
Thad
__________________
1994 F350 XL Crewcab 4x4 SRW 7.3 E4OD Banks Turbo & "Custom" Exhaust
Dana 60 Sterling 10.25 3.55 285/75 16 Treadwright Retreads MTG's (love these tires), Pyro Install and Tekonsha Voyager Brake controller!
A little rough but its a truck not a show car!!!
In its former life it worked for the US GOVT
  #2 (permalink)
Old 06-30-2009, 09:42 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all Franklin2 is a name known to all
You won't lose much tranny fluid. If you are worried about it, you can get pieces of rubber line with bolts in them to plug the lines when you take them off.
Even if you get the tool for the fan, keep telling yourself over and over "left hand threads, left hand threads". I spent 30 minutes trying to re-install my fan till I suddenly realized I wasn't turning it backwards.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 06-30-2009, 09:26 PM
dakotajeep's Avatar
I just ordered a Transpro radiator from Auto Zone. Is this a mistake:
http://www.autozone.com/autozone/cat...estions=%5B%5D
Thanks
Thad
__________________
  #4 (permalink)
Old 07-03-2009, 12:29 AM
dakotajeep's Avatar
New Radiator=Problem solved!!!!
I could NOT be happier right now!!!
The thing went in smooth and works like a charm. The temps with the AC on only got up to 192F!!!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
