Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-30-2009, 02:18 AM
truvoice1 truvoice1 is offline
truvoice1 is starting off with a positive reputation.
Advice needed to replace headlight switch on 89 BII
Hi Everyone I have a 89 Bronco II. The headlight switch has always been kind of funky since I have owned the vehicle (4 years) in that when pulled out all the way only the headlights would come on and not the tail, parking or instrument lights. By very carefully manipulating the switch I could find a spot where all seemed to work. Well, recently, I have been smelling the sweet smell of burning insulation when the headlights are on and consequently I have been keeping my drives after dark to a minimum! Neither my Haynes or Chilton manuals have any useful information on replacing this switch; so I am curious as to what is involved in getting the old one out and a new one in. Do I have to take apart the dash board or can I get at it from underneath? Any help and/or advice would be greatly appreciated! Tom
  #2 (permalink)
Old 07-01-2009, 06:09 AM
fl1a fl1a is offline
fl1a is starting off with a positive reputation.
You might also check the multifunction (dimmer) switch in your steering column. The wiring to them burn and melt over time.
  #3 (permalink)
Old 07-01-2009, 09:34 PM
rebocardo rebocardo is offline
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
You do not have to take the dash apart, though it is a bit more tricky then the <=1988. If you drop down the fuse box (gently pull it straight down beyond the parking brake) it will be easy enough to disconnect the back on the switch.
I have a 1990 I am scrapping, I will try to take a picture of the open dash to help you out.
FWIW: You might have a loose wire in the connector.
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
  #4 (permalink)
Old 07-03-2009, 10:56 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
RBVs have issues with the headlight switch as they get older. I had to replace part of my wiring after replacing the switch thinking that would fix the problem. The wire for the running lights was not making a good solid connection and was overheating. Instead of putting a new pigtail on, I just did a quick repair to that wire with a quick-connect terminal lug, a butt connector, and about 2 inches of wire. I'd recommend either this fix or replacing the switch and pigtail - both are sold at most auto parts stores and it would be money well spent. FWIW, it's easier with the dash cluster removed if you can get your hand in there, but either method works - never thought of the other way until it was mentioned
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
