Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 11:51 PM
jetfiremuck jetfiremuck is offline
jetfiremuck is starting off with a positive reputation.
Mercedes Sprinter diesel engine
This is a question for Pablo UA the diesel guru. I just picked up a mercedes sprinter engine with a rod knock. It is a 2.7 5 cyl. It is missing the injection pump and intake but complete other than that. Can a non electronic njection pump and injectors be fitted to that engine? The bell housing and fllex plate look adaptable to another non mercedes trans? Regular Gas and Diesel are the same price where I live at $ 2.59/gal
  #2 (permalink)
Old 07-02-2009, 04:37 AM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
what an engine? its code? if it is EWE engine - you can swap with flight weight ing. pump but with turbo controll, if it is common rail (HPFP on front end engine) you can use it with CRD controll unit only. Well, just do some shots and post here and I can hekp you.
The better way to get parts - UK JYs.
__________________
_____________________________________
And makes us rather bear those ills we have
Than fly to others that we know not of?
  #3 (permalink)
Old 07-05-2009, 10:39 AM
i'm home now and I have Mercedes EPS and WIS and I'm reasy to help you. I need engine # (ore picture of engine ID plate) ore VIN of donor van. If you are offered to get CRD engine get it with PCM + keys + Immo module (it is hidden beyoung the instrumental cluster) + diagnostic socket and wiring.
Do not try to read codes with simple OBD-II scanner becouse Mercedes use KWP2000 (k-lene) protocole to program and diagnose you need Mercedes Star Diagnose C3, anyway andy MB dealer ore Detroit Diesel dealer has it.
It it is EWE engine (you can identify it with fuel pump with 2 connectors + EGR + boost controll valve - all is vac. controlled and Cranck pos. sensor in bellhousing) you need bosch PCM only (no immo). But you can downshift removing EWE pump, EGR and boost controll and swap it with traditional mechanical fuel pump.
__________________
Tags
common , crd , decode , diesel , engine , engines , knock , knocking , mercedes , rail , specifications , sprinter , swap , swapping , v6 , vin , wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
