Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 11:50 PM
BroncoChuck BroncoChuck is offline
BroncoChuck is starting off with a positive reputation.
Electrical gremlins?
Hi guys,
I have an 02 excursion with 7.3 PSD. Today the wife tells me the headlights and radio have been coming on by themselves on and off through the day and now it won't start.
I think the no start issue is low voltage from the lights /stereo being on, but what could cause the root issue?
I checked it out, after removing the ignition key it is fine for a short while (30 seconds or so) then the chime comes on like the key has been inserted and the gauges and instrument lights come on like it is getting ready to start.
The glow plug light is also coming on, the engine cranks slowly but won't kick over.
Any ideas where I should start?
  #2 (permalink)
Old 06-30-2009, 03:08 AM
Monsta's Avatar
Monsta Monsta is offline
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
I would put two new batteries in it.
__________________
Ken
Cats; nasty creatures...
  #3 (permalink)
Old 06-30-2009, 04:43 AM
CanadianSmokie's Avatar
CanadianSmokie CanadianSmokie is offline
2001 Ford Excursion
CanadianSmokie is gaining momentum as a positive member of FTE.
Kinda weird that it's trying to start itself.... do you have a remote starter on the truck?
__________________
Ken
Ratt X
2001 7point3 PSD
All Go...No Show
  #4 (permalink)
Old 06-30-2009, 09:58 PM
wallz's Avatar
wallz wallz is offline
2002 Ford Excursion
wallz is gaining momentum as a positive member of FTE. wallz is gaining momentum as a positive member of FTE.
Like Ken says, check your batteries, then check around main electrical box for any water. They are known to leak around the windshield and the water finds its way into there. Next check the wires coming out of the gear shift lever. They are also know to rub thru and create all sorts of problems with electrical.
__________________
2002 Excursion, 4x4, V-10, some mods, and many more to dream about!
  #5 (permalink)
Old 07-01-2009, 12:09 PM
Quote:
Sorry, I wasn't clear about what it is doing.
With the keys out, the headlights, radio, gauges and glow plugs all appear to be coming on. It isn't trying to start on its own.
  #6 (permalink)
Old 07-01-2009, 12:13 PM
Quote:
I am trying to get to the actual cause of the low voltage issue, which seems to be the ignition switch shorted to the accessory position internally.
I am thinking two new batteries would just get drained by the truck coming on without the key.
  #7 (permalink)
Old 07-01-2009, 12:19 PM
Quote:
Thanks for the tips.
Batteries were flat from the headlights and radio coming on. I put a charger on them and got it to start first thing this morning. Alternator is working fine.
Electrolyte levels in the batteries are good.
No water found in the electrical box; I didn't expect any since we live in the high desert LOL.
The harness in the column looks fine,; I don't see any wear marks or missing insulation.
Any other ideas?
I am letting the truck run a bit to see if I can get a full charge on the batteries. Could low battery voltage be the root cause here? Which came first, the chicken or the egg? Is the battery voltage low the cause for the bizarre action of the dash and gauges or is the instrument issue draining my batteries?
  #8 (permalink)
Old 07-04-2009, 02:36 PM
OK, I replaced both batteries. Things seemed fine with one exception: the trans temp gauge is stick in mid-range at start up. The next day we woke up to find the stereo is on again, along with the guages acting flakey without the key in again.
Any other suggestions? Or should I just bite the bullet and take it to the dealership?
  #9 (permalink)
Old 07-04-2009, 11:11 PM
wallz's Avatar
2002 Ford Excursion
With your new batteries in and still problems, I would tend to think that it would be the gem module. And I think that is a dealer replace item. Good luck with that one.
__________________
  #10 (permalink)
Old 07-06-2009, 05:35 PM
I charged the new batteries this morning to take the truck to the dealer, and now I can't get it to act up again. No headlights on, no gauges twitching, no stereo. Just acts like its supposed to now.
The only problem now is that the tranny temp gauge is stuck at mid range, even at start up. Not sure if the eliectrical issue cooker it or not, but other than that it isn't doing anything crazy right now. I don't want to take it in to the dealership on an intermittent fault when it isn't doing it.
  #11 (permalink)
Old 07-23-2009, 12:24 PM
Just an update on this:
I sprayed some teflon based dry film lubricant into the ignition key and worked it back a forth several times. To me, it seemed that something inside the switch was sticking in the accessory position even with the key out. It didn't help, so I made an appoinment with the dealer and dropped it off two days later.
After I made the appointment, it didn't do it again. I told the dealership that I had an intermittent electrical fault that wasn't currrently doing it. They couldn't induce the fault either. The tranny temp gauge being stuck mid range is either a sending unit in the pan or the gauge itself, which can only be isolated by dropping the tranny pan.
  #12 (permalink)
Old 07-23-2009, 12:39 PM
soutthpaw's Avatar
soutthpaw soutthpaw is offline
soutthpaw is gaining momentum as a positive member of FTE. soutthpaw is gaining momentum as a positive member of FTE.
all those symptoms can be from a loose or corroded ground connection or cable somewhere...
__________________
DJ
ASE Master Auto Technician.
2001 Excursion 4x4 7.3, 4" lift & exhaust,ISSpro gauges
PHP Phoneix/Minotaur Chip, Transgo, DIY 6637 Mod, BD 200A alternator
2000 International 4700 T444E Project Truck
  #13 (permalink)
Old 07-23-2009, 01:25 PM
rosco_p_coltrane's Avatar
rosco_p_coltrane rosco_p_coltrane is offline
rosco_p_coltrane is starting off with a positive reputation.
Yup I agree...it sounds just like a bad ground someplace...check em all.
__________________
2003 Excursion Limited 6.0 diesel 4x4, 4" Pro Comp Lift, Centerline Vector 16x8 wheels w/315/75R16 Toyo Open Country A/T's, and a Fabtech dual opposing steering stabilizer. All black.
1996 F-150 4.9 4x4 standard cab long bed. Pacific green.
2007 Yamaha R-1. Red.
1996 Honda XR600R. Black/Red
1967 Triumph TR6C 650. White/Black
  #14 (permalink)
Old 08-07-2009, 11:56 PM
cohusker cohusker is offline
cohusker is starting off with a positive reputation.
Any luck ???
Did you have any luck on fixing your problem, my 03 ex just started doing similar things today. When i take the key out the battery light is faintly on and then 15 sec later the radio and odometer come on. The past few days it has been starting like the battery's might be a little low but there are 11volts on each.
Let me know if you found anything that fixed your problem
thaks
cohusker
  #15 (permalink)
Old 08-08-2009, 12:31 AM
Monsta's Avatar
Sit. Stay.
2005 Ford Excursion
11 volts IS low...
__________________
Ken
Tags
2002 , electrical , excursions , ford , gremlins
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
