Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 08-09-2009, 08:27 PM
BroncoChuck BroncoChuck is offline
BroncoChuck is starting off with a positive reputation.
Both batteries had dead cells in them according to my charger, so I replaced them. That did not fix my issue. I sprayed some teflon based dry film lubricant into the ignition key and worked it back and forth several times with the key in between start, run, accessory and off positions which fixed the problem. It seemed like dust gummed up an internal switch of some type in the column and the dry film lube broke it loose.
I haven't had any problems since.
Tags
2002 , electrical , excursions , ford , gremlins
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
