Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 11:37 PM
jack71 jack71 is offline
jack71 is starting off with a positive reputation.
Start up procedures & tips
Hey folks,
I'm hoping to get my 292 running this summer. I'm close to getting the painted cab back on the frame and wiring should go smoothly after that. Ideally, I'd like to get this engine running! Its a rebuilt 292 with ramshorns and an edelbrock carb w/ an MSD ignition. So... not quite stock but still a Y block!
First question is how to prime it -- can I use the distributor shaft w/ a drill trick? Also, what should I use for initial timing? I think the builder advanced it a bit for startup.
My last question is about the oil pan & dipstick. The rebuilt engine was from a car. I switched the correct oil pan, but the dipstick is still located in the front. So the dipstick hits the bottom of the pan.
Can I just trim the dipstick and score a new 5qt line on it? Moving it to the middle will be tricky with the ramshorn manifolds. The back location might work but that sounds like a lot of work now that engine is bolted to the frame with a tranny attached.
Thanks in advance...
Jack
  #2 (permalink)
Old 06-30-2009, 01:48 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Quote:
Originally Posted by jack71 View Post
Hey folks,
Jack
Hi Jack,
You can prime it with dist. removed, using either an old dist. shaft or one purchased at the parts store. Make sure the drill runs in reverse since the dist. turns counterclockwise.
Try 8 degrees initial timing, and check with light as soon as possible after start. 8-10 degrees is the norm.
On my previous truck engine I had a front dipstick, trimmed down with a mark scribed at 5 quarts full. Never felt real good about it. Once I drained the oil and carefully measured the amount that came out. Dipstick showed between full and 1/2 quart low. It was actually 1 1/2 quarts low.
If there is a new cam and lifters do the cam breakin on first startup. Make sure a good oil with ZDDP is used, and it wouldnt hurt to add CompCams breakin additive.
If the rebuild is for a car you will need a truck timing cover. Another difference that may or may not have to be dealt with is the water pump shaft, 5/8 in. car 3/4 in. truck. Cars had slightly larger water pump pulleys too. I use a car pump and pulley in my '46. The larger pulley slows down the pump speed a little, but no problem if you arent making a workhorse.
I had to shorten the dipstick housing a little, maybe 6-8 inches for my Rams Horns. Then bent it into a radius, and shortened the dipstick an equal amount, scribing a mark at full and one quart low.
__________________
COLOR=Navy]1946 1/2 ton with Y-block
1964 F-250, 292 4 speeed
1990 Ranger 4WD
  #3 (permalink)
Old 06-30-2009, 09:14 AM
Thanks so much for the help.
Fortunately I do have the truck timing cover, so I'm all set there.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
