My old cleveland from the donar truck had 2 1/2 exhaust with flowmasters that exited in front of the rear tires. With the application I described would this truck benefit in the least from cutouts? If I'm going to add them I might as well do so while I'm getting the exhaust welded up.
Thanks
__________________
1966 F-100 Custom Cab (work in progress)
351 Cleveland 4V (DOAE-J) *No its not a 351M**
C4 trans, 4.11 trac loc
Ground up resto. Ground is done, ran out of money for the up.
I've heard a few friends mustangs with cutout's. They are very loud. I personally like the sound.
__________________
1981 Ford f-100 302 windsor/C6/3.25/9.0 rear
Bass, walleye, catfish, and trout, im tellin you now you'd better look out! You were safe in the lakes when i was home wishin. But be on your guard cause im goin fishin!
When one considers the affects that a full exhaust has on the calibration of a carb, we can determine that a cutout will have no positive affects on performance. Matter of fact, if the carb is tuned properly, then the exhaust is opened up the calibration is no longer any good. This could have ill effects on the overall performance.
Now you can calibrate for the open condition, but this means that the calibration will be wrong when the exhaust is closed. So where is the real performace? There is a fine line, and a balancing act, but seems much easier to tune for one condition and keep all of the variables out of the equation.
As an example, I see many vehicles uncork the mufflers at the track only to ET slower than with muffler left on. Carb calibration is funny that way.
While this may be true, the cutouts are more for showing off anyway. When you want performance, left them capped, and open them when you want to make some noise.
Thanks for the comments. My real interest was in performance and some intimidation. I was planning on adding dumps with electric cutouts. Sounds like thats $400 I should probably just invest in my stereo equipment.
__________________
Screw those electric cut-outs, just buy some manual ones that are wire operated for like 50 bucks. I think they're fun when a ricer pulls up next, open them up and drown his fart can out.
__________________ It's an internet forum, get used to it. It's like having a drunk conversation with every single person in the bar minus the "I love you man". "I've seen far more abnormal and unexplainable things at Wal-Mart than I have out in the deep woods." "My drinking crew has a racing problem, or vice versa..."
