Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 10:26 PM
Don S.'s Avatar
Don S. Don S. is offline
1978 Ford F-150
Don S. is starting off with a positive reputation.
95 Ford AeroStar install question.
Seems it should be simple, and I should know this, but here goes.
So I am installing a Kenwood HU, into a 95 Ford Aerostar. I noticed with the wiring adaptor, There are two one grey and one black, I noticed the speakers were reading speakers impedance except one set.
SO I thought to myself, okaaaaay, so went to ohm out the other speakers using the one ground on the working set. and it seems that the speakers are common ground. Colors off of the aftermarket harness adaptor.
White and white/Black = 3.5 Ohms
Green and white/Black = 3.5 Ohms
Purple and white/Black = 3.5 Ohms
Grey and white/Black = 3.5 Ohms
When putting Green and Green/Black reads open, same with all other clolrs except White and white/Black = 3.5 Ohms.
So with long drawn out explination, my question is this, Do I just tie all the speaker lead grounds to that single ground? Or am I going to need to run seperate wires to the 4 speakers due to them being common gorund to make them not common gorund?
Will hooking up the 4 channel ground to one common tie point end up burning up the deck as f it were tryiing to use the deck output in a bridged configuration.
The reason I ask this because in all my own installs I have always rewired for the speakers.
__________________
Committee: a group of the unwilling, picked from the unfit, to do the unnecessary.
"Brutus" 1978 F-150 SC 4x4 BB460
" There is a very fine line between "hobby" and "mental illness."
" -Dave Barry, Nationally Syndicated Columnist
  #2 (permalink)
Old 06-29-2009, 10:52 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
I wouldn't use a common ground. I assume your looking at something like this
Quote:
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Red or Black
Illumination Blue/Red
Antenna Trigger Orange/Blue
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
I would first verify your adapter wasn't made on a monday morning or friday afternoon and they match up to what they should. If they match up, then I would try the battery trick to see which wires go to which speaker. If you come up with the same info, I'd pull the speakers to look for shorts, baring shorts, then I would run new pairs.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 06-29-2009, 11:03 PM
Don S.'s Avatar
1978 Ford F-150
Yeah Actually every speaker works if I tie all the kenwoods negative speaker leads to the harnesses White/black. then the corresponding positive lead together i.e. purple lead from the kenwood to the harness adaptor.
So it's like this,
White = Front L +
White/black = Front L -
Grey = Front R +
White/black = Front R -
Green = Rear L +
White/black = Rear L -
Grey = Rear R +
White/black = Rear R -
I verified this with powering each speaker off of the headunit. One channel hooked up then ran through the various ways to hook it up.
So that is the only way there is sound from the speakers. So I am going to have to re-wire the speakers then I guess.
__________________
  #4 (permalink)
Old 06-29-2009, 11:10 PM
ReAX's Avatar
2002 Ford F-250
If you want to sound good, that's what I would suggest.
__________________
  #5 (permalink)
Old 06-30-2009, 02:43 AM
Don S.'s Avatar
1978 Ford F-150
Yeah I usually go that route with any of my own installs, this wa just some eles rig. I jusy have never had to deal with a common groud setup.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
