Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford ExplorerSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 09:12 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) is gaining momentum as a positive member of FTE.
Air bag code 33
The air bag lite is flashing 3-3 when you start up the truck. After several 33 codes it stays on constantly. I look up on internet and 33 is "passenger air bag open circuit". Pulled the glove box door and disconnected the wires and wiggled and reattached, still have code. Any one else had that code?
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 190,000 miles
2002 Explorer 4 x 4 4.0 XLT - 120,000 miles
  #2 (permalink)
Old 06-30-2009, 07:38 AM
shorod's Avatar
shorod shorod is offline
shorod is starting off with a positive reputation.
I'm going to assume you are referring to the 2002 Explorer listed in your signature file. According to the 2002 Factory Service Manual, a Lamp Fault Code of 33 is defined as "Restraint System - Safety Belt Pretensioner Status (Driver Pretensioner Circuit Fault)." The service manual lists a pretty significant test of 20 steps for diagnosing this fault. If you're interested, I can e-mail you a PDF of the Pinpoint Test. Since I'm still new to this forum, I'm not sure if we have Personal Message capabilities for you to provide me with an e-mail address to send the PDF to.
-Rod
  #3 (permalink)
Old 06-30-2009, 07:52 AM
shorod's Avatar
It appears Ford released a TSB for the LFC of 33 in the 2002-2003 Explorer and Mountaineer. Article No.
03-11-3
-Rod
  #4 (permalink)
Old 06-30-2009, 01:01 PM
ncranchero's Avatar
ncranchero ncranchero is online now
ncranchero is gaining momentum as a positive member of FTE.
Pretensioner connector probably kicked loose under the seat.
__________________
________________________________
"Information is valued and appreciated...Attitude is not!"
Steve,
'98 F150 Super Cab 4x4 SOLD, '99 Mustang 35th,
'02 Sport Trac 4x4, '01 Sport Trac Job 2 donor vehicle
'08 E250 Super Duty, No more Ranchero
  #5 (permalink)
Old 06-30-2009, 06:32 PM
steve(ill)'s Avatar
o.k., thanks guys. i looked up a site on internet and found different years had different codes. thought i had it narrowed down to passenger air bag, but that sure was not working for me. i will check seat belt and plugs on the DRIVERS side. Rod, i have not seen the TSB, i will see if i can find it. If i need the test procedure, i will write back.
__________________
  #6 (permalink)
Old 07-01-2009, 07:38 AM
shorod's Avatar
I didn't want to post a link to another forum, but since there's a direct request.... try this.
-Rod
Tags
2003 , 2004 , 32 , 33 , air , airbag , bag , blinking , code , code33 , codes , duty , explorer , f150 , ford , lfc , pdf , super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
