2002 Exsploder Issues
I might be able to give some insite in 2 of your 3 issues. The clicking in the rear of the truck could be from the AC/Heater unit blend door. If it is the blend door, the fix is the same as the blend door up under the dash, or a temp fix is to pull the # 24 or 25 fuse. As for the EGR prob, pull the code, if it reads PO401 then you have a DPFE sensor that has goon bad, like mine, you will need to replace it and then have the system reset with a code reader or remove the neg side of bat for 15 min, hope this helps
