Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 09:04 PM
daddy172005's Avatar
daddy172005 daddy172005 is offline
daddy172005 is starting off with a positive reputation.
4 Wheeler Questions and Problems
I just bought my son a used small fourwheeler. I have no clue what kind or what size it is. This is the first fourwheeler that I have ever dealt with. The question I have is if their is any kind of transmission fluid that goes into this thing. The problem I am having is when you get in the throttle it wants to cut back and not pull. I changed the sparkplug and cleaned the carb. It ran better afterwords but still cuts back and doesn't want to go. Any thoughts or suggestions would be appreciated.
__________________
Mason
74 F100 302
  #2 (permalink)
Old 06-30-2009, 12:13 PM
workinman workinman is offline
workinman is starting off with a positive reputation.
I've had a few 4 wheelers, and none of them have separate transmission fluid . On my Honda 250ex, there is a lock nut to adjust the clutch ( manual tranny, no clutch). My Kaw 650 uses a CVT transmission so the belt is really the only thing to adjust. My cheapy china 90 has an 'auto trans' that never worked very well ; seems like maybe it has a wet centrifugal (?) clutch plates , and they don't engage very well.
Does it sound/feel like the clutch is slipping or is the engine bogging down ? What kinda of drive train/clutch does it have ?
If you have give us a few more details and/or some pics, maybe we can help more...
thx/good luck,
jeff
  #3 (permalink)
Old 06-30-2009, 03:33 PM
PupnDuck PupnDuck is offline
PupnDuck is starting off with a positive reputation.
This may be a silly question but is it full of FRESH gas? I've had similar problems with my Honda when the gas in the tank was a couple of months old.
  #4 (permalink)
Old 06-30-2009, 09:11 PM
Yes I drained the tank and filled it with fresh gas before i started it. I think its its a "China Special". Don't know about the size. Must have had trash somewhere because it cut off and when i cranked it back up it ran a whole lot better. Still having a problem with it not wanting to pull from a dead stop or going up a hill. I think i may have an issue with the clutch. Seems like its slipping at times and not engaging at other times. It does fine going downhill. The chain is continuosly jumping teeth so thats another thing to work out. My son can ride it some now as long as i push it to start off. Hes already had his first wreck.
__________________
Mason
74 F100 302
  #5 (permalink)
Old 07-04-2009, 07:57 AM
Bobby82490's Avatar
Bobby82490 Bobby82490 is offline
Bobby82490 is gaining momentum as a positive member of FTE.
Some of those small ATVs have safety features on them. Some are throttle limiters, cvt limiters, or a variation. Look to see if the carb butterfly is opening fully and if it is a CVT(Constantly Variable Transmission) see if the belt is worn bad, it should have a little play but not sloppy.
__________________
-Gone with the 250,000+ '98 F-150
-2002 FX4 Lariet F-150
-5.4/4r70w, 3.55LS, 130,000m
  #6 (permalink)
Old 07-05-2009, 10:38 AM
It doesn't have a belt. It just has a chain. It will go once you get going but starting off is a problem.
__________________
Mason
74 F100 302
  #7 (permalink)
Old 07-05-2009, 02:21 PM
Bobby82490's Avatar
Although the final drive is belt... some of those small atvs have a belt driven transmission, kind of how autos have a torque converter. Is it a single speed or do you have to shift it?
__________________
  #8 (permalink)
Old 07-13-2009, 12:15 AM
littleme13's Avatar
littleme13 littleme13 is offline
littleme13 has a good reputation on FTE. littleme13 has a good reputation on FTE.
look near the thumb throttle there should be a little screw that restrics how far you can press the throttle open.
  #9 (permalink)
Old 07-13-2009, 07:47 AM
Bobby82490's Avatar
Quote:
Sorry I meant even if the final drive is chain.
__________________
  #10 (permalink)
Old 07-17-2009, 03:02 AM
It goes one speed. It moves good enough now for him to ride.
__________________
Mason
74 F100 302
Tags
1998 , 250ex , 4wheeler , belt , bogging , cvt , diagnosing , dont , fluid , fluids , honda , problems , replacement , sale , size , transmission , wheeler
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
