Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 08:51 PM
bkvanbek bkvanbek is online now
bkvanbek is starting off with a positive reputation.
Differential leak, naive owner.
I changed differential oil this winter, no leaks afterwords, but now there is oil all over and a couple drops on the driveway from overnight. I think it is the seal from the drive-shaft, maybe the cover too.
And How do I replace the seal, and how do I figure out what axle I have?
__________________
2003 F 350 XLT Sport 4x4 6.0L Diesel
Bank's Big Hoss with PDA
  #2 (permalink)
Old 06-29-2009, 09:51 PM
joe blow's Avatar
joe blow joe blow is offline
Don't take my last beer
joe blow is starting off with a positive reputation.
IF YOU HAVE AN F250/F350.......I am certain you have the Sterling differential.
How much fluid did you put back in? If you overfilled it, that is as bad as running it with not enough differential fluid.
The front seal and the differential cover leaking AFTER you did the fluid sounds like too much fluid......if not...
The diff pan is not sealed correctly....remove and MAKE SURE it is straight (sealing surface)
The pinion seal is a little more difficult....no disrespect intended, but according to your post header "naive owner" it might be a little more challenging since it needs to be retorqued once the seal is replaced. You'll need a torque wrench.
  #3 (permalink)
Old 06-29-2009, 09:55 PM
It was six months ago I changed the oil and I am sure I did not overfill it, you fill it until it comes out the fill hole, right?
I do have a torque wrench, up to 150#, air wrenches and big sockets. What does it take to change it?
__________________
  #4 (permalink)
Old 06-29-2009, 11:13 PM
jboczar jboczar is offline
jboczar is gaining momentum as a positive member of FTE. jboczar is gaining momentum as a positive member of FTE.
Remove drive shaft, remove rear calipers to eliminate drag, installed torque wrench onto pinion nut inside flange, record torque required to turn nut. remove nut and use a 3 or 2 jaw puller to remove pinion flange, use a flat head screwdriver and hammer to remove seal. Find a suitable device to fit over new seal and using a hammer drive it in, Ford has a special tool but anything like a large socket that fits well over seal will work. reinstall pinion flange and use nut to draw it in. Use torque wrench to check turning force, it should be 5 inch pounds more than original turning force.
  #5 (permalink)
Old 06-30-2009, 06:45 AM
Thanks for the help.
__________________
  #6 (permalink)
Old 06-30-2009, 02:02 PM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
Before you do anything, check the vent hose. If the vent is blocked, high temps will make it burp oil out the pinion seal. There is a hose that comes off the top of the differential and goes to the frame rail, make sure the end of it is clear and you can blow air through it (with your mouth, not an air compressor). Here in Oregon they get plugged up with leaf-cutter bees a lot.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
  #7 (permalink)
Old 06-30-2009, 08:48 PM
Radical's Avatar
Radical Radical is offline
1988 Chevrolet Corvette
My Garage
Radical is starting off with a positive reputation.
Funny you mention the leaf cutter bee's plugging the breather, I just finished evicting 3 bee larva (think they were mason bee's here on the coast) out of my breather as it was starting to burp fluid on my driveway. Another problem solved
  #8 (permalink)
Old 07-01-2009, 12:52 AM
pjwoolw's Avatar
pjwoolw pjwoolw is online now
pjwoolw is gaining momentum as a positive member of FTE.
I use a small fuel filter instead of the vacuum tee from the factory.
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
  #9 (permalink)
Old 07-01-2009, 06:17 PM
I checked mine, it was clear, but I think the cover must leak too.
__________________
  #10 (permalink)
Old 07-03-2009, 08:40 AM
I loathe putting the oil back in the differential, there must be a better way.
__________________
  #11 (permalink)
Old 07-03-2009, 08:47 AM
joe blow's Avatar
Why do you loathe doing this? Most if not all differential fluid containers come with a spouted plastic end....I don't think it is that messy....certainly not difficult.
  #12 (permalink)
Old 07-03-2009, 09:10 AM
I don't find it easy at all. It takes many minutes to get a quart in the differential, spilling some. A friend of mine helped with the seal, he complained about putting the oil in too.
__________________
  #13 (permalink)
Old 07-03-2009, 03:11 PM
Radical's Avatar
My Garage
A funnel can help if you can fit it in.
  #14 (permalink)
Old 07-03-2009, 04:35 PM
Just be sure and have the oil warm, 80-90 degrees and its a lot easier. I filled mine when it was under 40 degrees in our shop and it took a while to squeeze that cold thick fluid out the nozzle.
__________________
Tags
1025 , 2001 , 2005 , axle , cover , differential , f150 , f250 , f350 , fluid , ford , leak , leaking , leaks , sterling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
