Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 08:46 PM
r0n1n's Avatar
r0n1n r0n1n is offline
r0n1n is starting off with a positive reputation.
electrical problem.....
i've been having what i thought were problems with the alternator, where the voltage needle bounces back and forth, i just replaced the alternator and i still have the problem. only now it just seems to bounce back and forth a little but the needle never dropped to the left like before. i used a test light and there is no short in any of the circuits. the battery before starting the truck was ~12.55 but now after driving back from checker, about 15 minutes, i turned the truck off and the battery voltage is 12.98
also, when i turn the ac to max the voltage needle stops bouncing and just stays in the middle. any ideas? i read somewhere that the gauge can lose it's damping???
thanks, jason
__________________
A new terror born in death, a new superstition entering the unassailable fortress of forever. I am legend.
Jason
  #2 (permalink)
Old 06-30-2009, 09:29 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold Franklin2 is a splendid one to behold
At night with the lights on, if they blink with the voltage gauge, then you might have a problem with the charging system. If they are steady, but the gauge still varies, it might be the gauge.
__________________
Dave F
1989 F250 XLT Diesel
  #3 (permalink)
Old 06-30-2009, 11:04 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all
Have you checked the electrolyte level in the battery (s)?
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
Join the Maryland Chapter click HERE
  #4 (permalink)
Old 07-05-2009, 10:09 AM
r0n1n's Avatar
at night the lights flicker when the gauge bounces,although i drove for 3 hours and when i stopped i tested the battery and the voltage was 12.7. so it is charging. the whole trip the gauge was bouncing back and forth.
__________________
Jason
  #5 (permalink)
Old 07-05-2009, 12:46 PM
Franklin2's Avatar
I don't know what year truck you have, but if you have the separate regulator system, run a ground wire from one of the regulator mounting bolts to the battery negative, and see if the problem goes away.
__________________
Dave F
  #6 (permalink)
Old 07-05-2009, 04:24 PM
r0n1n's Avatar
sorry, 97 F250 w/ 7.5L it's an internal regulator, and i just got the alternator and reg replaced. the battery was bought in march 09, but i'll get it tested to see if there's a bad cell.
__________________
Jason
  #7 (permalink)
Old 07-05-2009, 11:44 PM
Franklin2's Avatar
Take a jumper cable and clamp one end to the alternator housing, and the other end to the battery neg. If that doesn't make it go away, I would check the plugs on the alternator to make sure they are not melted or corroded inside. If they are ok, I would get another alternator. You will not be the first to get a bad alternator if it's a rebuilt unit.
__________________
Dave F
  #8 (permalink)
Old 07-06-2009, 10:10 PM
r0n1n's Avatar
i hooked up a cable to the alternator and to the neg battery post, no change. i've checked the plugs on the alternator and they seem fine. this is the second alternator that i've had this problem with, so i don't think it's the alternator. the last alternator i had tested fine at o'reilly but a guy was nice enough to exchange the alternator anyway. with the lights dimming and the sound it's making, it seems as if the alternator is charging in spurts. i'm at a dead end with this, any new ideas?
thanks, jason
__________________
Jason
  #9 (permalink)
Old 07-07-2009, 12:40 PM
BPofMD's Avatar
Old-Timer
Get another alternator.... I've seen people have to swap 'em more than twice to get a good one.
__________________
BPofMD - Bud
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
