np435 gear ratios - Ford Truck Enthusiasts Forums
np435 gear ratios
Old 09-21-2001, 04:06 AM
7855F100 7855F100 is offline
7855F100 is starting off with a positive reputation.
np435 gear ratios
dose any 1 know the gear ratios for the np435 1tru 4 sence ford forgot to put it in there 78 and 79 sevice manuals.
thanks
Old 09-21-2001, 08:34 AM
lanero lanero is offline
lanero is starting off with a positive reputation.
np435 gear ratios
1st - 6.69:1
2nd - 3.34:1
3rd - 1.66:1
4th - 1:1
I just put one in my truck, so I happened to have the numbers handy.
Roger Lane
Test Analyst
Sr. Automated Test Engineer
IBP, Inc.
Old 09-21-2001, 08:49 AM
np435 gear ratios
dose any 1 know the reverce gear ratio thanks
Old 09-21-2001, 09:12 AM
Eddie Eddie is offline
Eddie is starting off with a positive reputation.
np435 gear ratios
8.02
Eddie
Old 09-22-2001, 11:00 AM
hotboat1 hotboat1 is offline
hotboat1 is starting off with a positive reputation.
np435 gear ratios
Hi, The NP435 was used in trucks (Ford & Others) from 1964-1987 and was produced with 2 different ratios ! The first was a close ratio which had a 4.78 1st, 2.39 2nd, 1.37 3rd, 1.00 4th. The other (more commenly used) has a wide ratio 6.69 1st,3.34 2nd,1.79 3rd,1.00 4th.They also made these with 2 different lenght tailhousings and shafts, the long tailshaft is a 14.5 inch, I don't recall the length of the short but I want to say it was eather 7" or 8.5", the short shaft used in Ford trucks was primarily used in heavy duty trucks (1 ton and up). The long shaft is the one most light duty truck owners look for as it's a direct bolt in replacement for the 3 speed box with column shift. Keep in mind depending on your differential gear ratio the first gear on this trans may be of little use during daily driving and you will more than likely find you have a 3 speed on the floor instead of a 4 speed, opt for a 2.75 gear out back. If you simply don't like the column shifter Hurst makes a floor shifter conversion kit just for this application, simple matter of cutting hole in floor for shifter and installing a shifter boot! This is by far both cheaper & easier than a gearbox swap. Hope this will help somebody out, Dan H. (hotboat1)
Old 09-22-2001, 01:39 PM
np435 gear ratios
thanks for the realy good input
Old 10-06-2001, 07:16 AM
StockMan's Avatar
StockMan StockMan is offline
StockMan is starting off with a positive reputation.
np435 gear ratios
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
Where are you guys getting the ratios from because I see a discrepency on 3rd gear?
[/FONT]
http://www.ford-trucks.com/dcforum/User_files/StockMan/flag.gif
[FONT COLOR="#ff0000" SIZE="+2" FACE="Bassett"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="3" FACE="arial"]
[LINK:www.ford-trucks.net/users/stockman|Stockman's Club FTE Site]
[LINK:www.67fordtruck.com|1967 F-Series Registry ( www.67fordtruck.com )]
Old 10-07-2001, 09:27 AM
farmtruck21 farmtruck21 is offline
farmtruck21 is starting off with a positive reputation.
np435 gear ratios
Old 04-15-2011, 09:58 AM
Maverick1978's Avatar
Maverick1978 Maverick1978 is offline
Maverick1978 is starting off with a positive reputation.
I heard 3rd gear was 1.74
Old 04-15-2011, 02:13 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
NP 435 gearing turbohunter 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-02-2014 09:31 PM
np435 1mouse3 1967 - 1972 F-100 & Larger F-Series Trucks 17 02-03-2012 11:13 PM
gear shift removal NP435 kingford72 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-19-2011 09:02 PM
Close-ratio GM NP435 Ken Blythen Clutch, Transmission, Differential, Axle & Transfer Case 6 09-20-2008 10:07 PM
Np435 gear ratio Doorgunner808 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-27-2002 01:16 PM
Tags
435, arrange, conversion, ford, gear, gearbox, np, np435, process, ratio, ratios, reverse, revised, transmission, wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
