Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 06:42 PM
zachsherman88 zachsherman88 is offline
zachsherman88 is starting off with a positive reputation.
Unhappy burning oil in cylinder
ive got a 400 motor that ive recently installed a new crank kit in ive basically rebuilt the motor except for the pistons and cam bearings and i seem to have oil getting into the passenger side rear cylinder as your looking at the front of the motor its been doing this even before i put the crank kit in and i put all new valve stem seal on thinking that was it but still had the problem my dad thought it could be the piston rings especially since i have not yet replaced them or the rings but i ran a compression test on that cyllinder and compression was up to 140 psi and it only leaked 5 psi over 15 min so i don't know my only guess is that it might be the valve stem seal sticking to the valve and allowing oil under the seal when the valve closes but im not sure what do you guys think?
  #2 (permalink)
Old 07-03-2009, 12:00 AM
mustang81 mustang81 is offline
mustang81 is starting off with a positive reputation.
It might not be your 2 compression ring but your 2 rails and your expander. The oil ring does not seal the combution pressure. My 02
  #3 (permalink)
Old 07-03-2009, 11:30 AM
hollenjoe's Avatar
hollenjoe hollenjoe is offline
hollenjoe is starting off with a positive reputation.
Mine had the same prob, had new guides and everything but my valves were worn, since the engine is alway a bit tilted to the back, a small pool of oil forms in the back of the top side of the cylinderhead (where rockerarms are), so the back cylinders (4,8) are prone to sucking oil thru the exaust valve, and since the passanger side has the exhaust valve last, its the one thats gona suck more oil..... Dissasemble the spring/seal from the number 4 exhaust valve (remember to have that piston up or the valve will fall) and move the valvestem with your hand, if it has to much clearance thats your problem, you can fix it maybe by adding a small rubber o-ring on top of the seal plus adding thicker oil, or by getting new valves
__________________
"Drive it like you stole it..."
  #4 (permalink)
Old 07-19-2009, 01:39 PM
it seems like that might be the case i took out the plugs and most of them looked good except the back 2 cyllinders 4,8 i just put a new valve stem seal kit on all the valves so they may be sticking to the valve allowing oil to get under the seal when the valve closes is there any way to keep the seals from sticking to the valve so that it stays down to the guide?
  #5 (permalink)
Old 07-19-2009, 09:30 PM
hollenjoe's Avatar
I hate this sealing system, theres 2 thing you can do, yo can run a quarter oil less (you could be running excess oil too), and seal the last 4 valves with an O-ring on top of each umbrella...
__________________
  #6 (permalink)
Old 07-20-2009, 02:10 AM
just thought of an idea im going to try tommorow im going to put some springs on the valves that will push on the valve seal and put some tension on it to keep it from sticking to the valve. should do the trick hopefully. i'll let you know how it goes
Tags
burning , cylinder , ford , oil , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
