Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 05:05 PM
cv18sro cv18sro is offline
cv18sro is starting off with a positive reputation.
Brake question
When I bought my 01 Ford F150 5.4 4x4 ext cab at around 40,000 miles the brakes were very hard. I would apply the brakes and the truck did not seem to want to stop. I assumed prior to the lease return the previous owner put some very hard brake pads on. There was absolutely no dust from the pads. At 50,000 I decided to change them and put new rotors and NAPA's mid grade pads on them. They were great for about 10,000 miles and then the same issue as before.
Now I am thinking maybe the rears are not adjusted properly, it just seems that the fronts are doing all the work instead of 60% of the work.
Anyone else had this issue and is it an issue with these trucks. If I have to mash on the pedal it stops fine, it just seems like a hard pedal. The master cylinder is not leeking and I have never had to add fluid. Maybe its time for a complete system blead.
Any suggestions and what pads and shoes are you guys using. I am at 80,000 now so I am probobly due for front and rears.
  #2 (permalink)
Old 06-30-2009, 10:00 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) is gaining momentum as a positive member of FTE.
i think i would look at the calipers and see that they all move- slide easy. might be worth bleeding each corner just to see that you have flow, no restirction, and that the pucks are moving in the caliper. might have colapsed hoses on one end and no flow? if it had airn you would have a mushy pedal. look at each disc. do they all show wear/ grooves like they have been working?
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 190,000 miles
2002 Explorer 4 x 4 4.0 XLT - 120,000 miles
  #3 (permalink)
Old 07-02-2009, 12:36 AM
I pulled the front wheels off today to inspect. The pads are thin but at least 6000 miles left on them before mandatory replacement. The rotors look good, no cracks or hot spots, they are pretty smooth considering the pads almost gone. I could not check the flow no help today.
I am almost due for a trans service so when I take it in to the shop, I am gonna have them check it and do a complete fluid replace on the brakes. The fluid in the master cylinder is pretty dark. While there at it I will have them check the calipers.
A visual inspection of the lines showed no kinks or anything abnormal.
Since you mentioned calipers that could be the issue and your comment about them makes sense to what is going on.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
