Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 04:32 PM
URX111 URX111 is offline
URX111 is starting off with a positive reputation.
1989 Ranger What oil to use???
I have a 1989 Ranger with 180,000 miles on it. I was wondering what oil is the best to use. Last oil change I used 10/40 and some STP additive.
Is this OK or is there something better? Do the lifters need Zink, or what?
TNX Paul
  #2 (permalink)
Old 06-30-2009, 02:05 AM
lowdownndirty lowdownndirty is offline
lowdownndirty is starting off with a positive reputation.
Ive always ran 10/40 castrol in my ranger's. and never had a problem.and most of them get driven like a basturd child at a family reunion.
  #3 (permalink)
Old 06-30-2009, 07:28 PM
Thanks for your reply
Thanks Lowdownndirty
I think last time I used Shell Rotella 10/40 or something like that.
Next time I'll use the same or Castrol .
TNX Paul
  #4 (permalink)
Old 06-30-2009, 09:54 PM
pawpaw pawpaw is online now
pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE.
TNX Paul
Good grief, your using STP with 10W-40, that would make a concoctcion that would be something like 20w-50 or so, about like gear oil!!!! Don't know where you live, or under what conditions you operate under, but that OHC engine wasn't designed to run on lube anywhere near that viscous!!!!
I see you've asked this queston about your 189K mile 1989 2.3L on the 4cyl forum & haven't recieved any answers.
Not sure what Ford specified for that engine back in 89, but it was probably 10W-30 & later 5w-30 & is now 5W-20.
If your not in hot country, that engine sure is suffering during cold weather, having to try to pump such a viscous brew & the OHC needs cam lube Fast, on cold starts!!!!
So, I'd loose the STP in the mix & look to a good quality 10w-30, or 5w-30, or maybe even try Motorcraft 5w-20 thats been back specified for most engines since about 01, if it isn't leaking, or burning oil.
Some engine lube thoughts for pondering.
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles but trifles make perfection & perfection is no trifle
(Ben Franklin)
Our signature is a sign of a job completed autograph your work with excellence
  #5 (permalink)
Old 06-30-2009, 10:49 PM
Bear River Bear River is offline
Former Vendor
Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE. Bear River has a very good reputation on FTE.
You should be using 5W30 or 10w30 unless the rings are extremely worn. Even thought he truck is an '89, it will love you for using a lighter oil. 10-40 is thick enough that it will cause excessive startup wear the only time you should use the 10w40 is i you are in a very hot climate like Phoenix. If you use the right oil, no additives are needed or recommended. Most engine wear occurs at startup. The faster your oil flows and pressure builds, the less wear, and the longer the engine can last. Heavy oil flows slower and takes more effort to pressurize. Some claim the thicker oil doesn't drain off the parts as much, but you will not notice a difference between a 5w oil and a 10w oil in terms oil residue left when the engine is off.
  #6 (permalink)
Old 07-01-2009, 01:01 AM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
Gonna be a daddy!!!
2002 Ford Ranger
bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of bigrigfixer has much to be proud of
Yeah, it was pretty common back in the late 80's early 90's to run 10W30. Some ran 5W30. I would run the 5W30 myself.
__________________
Joe, who's GONNA BE A DADDY!!! drives an 02 supercab shortbed 3.0 liter automatic power nothing Ranger Edge.
BC Chapter Member
VOTE IN ROUND 10!!!
  #7 (permalink)
Old 07-01-2009, 06:55 AM
1st4x4 beach truck 1st4x4 beach truck is offline
1st4x4 beach truck is starting off with a positive reputation.
i run mobile clean 5000 10-30 truck seems to love it untill 4500 miles then i can feel a big hp loss, now i just change it every 4000 miles, with a K&N oil filter. i drive my truck on the beach alot and i like to take it threw the woods i think it would be fair to say that the truck gets put the the more then it should but its a ford and it will run for ever.
__________________
88 ford ranger 4x4 auto , 190,000 on the ticker and goin strong.. my first beach truck
94 ranger 2wd 5speed , 333,000 my first ranger, sold
  #8 (permalink)
Old 07-01-2009, 11:56 AM
02xlt3.0's Avatar
02xlt3.0 02xlt3.0 is offline
02xlt3.0 is starting off with a positive reputation.
I'd go with the 5w-30 also. It's bound to help your mpg.
__________________
2002 XLT Std Cab 3.0 Line-X, Sirius radio, back slider
94 T-bird, 92 Escort
05 Malibu (the wife's)
  #9 (permalink)
Old 07-01-2009, 09:09 PM
Thanks for your replys
It burns about 2 qts. every oil change 3000 miles. I'll try just 10/40 no STP.
THANKS Paul
  #10 (permalink)
Old 07-02-2009, 11:49 PM
sfcwoodret sfcwoodret is offline
sfcwoodret is starting off with a positive reputation.
Go with a fully synthetic Mobil One. Your engine will love it with all those miles.
__________________
2006 Ranger XLT
2007 Ford Escape XLT
2007 Ford Mustang Premium
  #11 (permalink)
Old 07-03-2009, 08:10 AM
THANKS Paul
Is it leaking the oil, or burning it????
If it's leaking any, maybe consider a "High Mileage" recipe oil, that says it has "seal conditioners" in it's formulation.
Several folks on the Ranger forum have posted positive results with Valvolene's high mileage product.
If it's really burning that much oil per OCI, but engine wear isn't exessive, the ring lands might be coaked up & the rings are sticking such that they can't make as good a seal as they're capable of.
So maybe consider an Auto-Rx treatment, to decarbon the engine & free up the rings!!!!!
I've not had to use it, but some of those that have, report a reduction in oil consumption, apparently from the ring lands & rings being freed up to make a better seal.
If it works for you to lower oil consumption, then maybe consider opting for the specified vicosity lube for your engine, it sure would appreciate it on a cold winter start up!!!!
If you decide to try this, lt us know how it goes.
http://www.auto-rx.com
More lube thoughts for pondering.
__________________
(Ben Franklin)
  #12 (permalink)
Old 07-03-2009, 09:43 AM
fraso fraso is offline
fraso is starting off with a positive reputation.
I would use a Heavy Duty Engine Oil (HDEO) rather than a Starburst Oil. These have plenty of ZDDP for anti-wear as well as strong deposit control additives to keep your engine clean. HDEOs are also designed to combat ring-sticking. For 10W-30 dino oils, you can go with Shell Rotella T, Brad Penn HDEO, PetroCanada Duron-E, and Exxon XD-3.
ACCCC Engine Oil Article
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
